New Parts...
Old Jul 21, 2009 | 01:53 PM
  #31
truckin151's Avatar
truckin151
Its just a slick little piece of equipment. And has the extra 2 ports for their other sensors like a wideband which I may be ordering a little later.
Old Jul 21, 2009 | 01:58 PM
  #32
Off_Road_Teacher's Avatar
Off_Road_Teacher
So it has ports built in for two additional sensors? That is nice especially for hooking up a wideband so you don't have to run a different gauge.
Old Jul 21, 2009 | 03:28 PM
  #33
truckin151's Avatar
truckin151
Okay cool feature... On start up you can have it display the mopar logo instead of their logo...
Old Jul 21, 2009 | 07:26 PM
  #34
Bertens's Avatar
Bertens
That is an awesome guage. Thanks for posting up on this, I would have never known what it could all do.
Old Jul 21, 2009 | 08:04 PM
  #35
Blown287's Avatar
Blown287
Truckin, thanks for being the guinea pig on this one, lol. If it can datalog all of the parameters it is capbale of monitoring, I will buy one. My wideband O2 is is "T"d into my split second so hopefully you can get a wideband O2 and split the signal to your gauge. Awesome man.
Old Jul 21, 2009 | 10:19 PM
  #36
truckin151's Avatar
truckin151
Blown, it has 2 ports on the back of the gauge for wiring in aux sensors so basically the wideband they sell can plug right into the gauge so it can be ran off the same gauge. It came with an adapter piece as well for hooking up your own sensor to it as long as it meets their electrical requirements.
Old Jul 22, 2009 | 10:23 AM
  #37
truckin151's Avatar
truckin151
On Start up now... (ignore the CEL, it pops on when you just have the key turned on, not running, and always has)
Quick question though on the temps, About where should thet be normally for trans and coolant? Right now my trans temp is displaying anywhere from 147* to 157* and the coolant temps show it right at 204* (the temp gauge in the truck shows the needle floating just below that center tick)
It was 104 in my garage this morning when I left for work and both the temps on start up showed a reading of 102* and then went up from there. I just want to make sure these readings are accurate since everything else is spot on...
Old Jul 22, 2009 | 10:40 AM
  #38
Blown287's Avatar
Blown287
That is awesome man. That could very well be the most awesome gauge I have ever seen.
Old Jul 22, 2009 | 11:06 AM
  #39
truckin151's Avatar
truckin151
The only thing Im curious about now is the accuracy of the temps. They seem to be about right, still curious about them though.
Old Jul 22, 2009 | 11:24 AM
  #40
SilverBullet08's Avatar
SilverBullet08
the trans seems pretty normal to me thats what im usually at...
