painting wheels
Old Jul 21, 2009 | 07:27 PM
mopardad68's Avatar
mopardad68
Question painting wheels
ive read a couple threads on painting wheels, i noticed no one mentioned weather or not you have to sand the anozadation[sp] off stock alluminum rims, they are stock rim[17's] and thats alot cheaper than buying new ones, any thoughts would help, besides, the balck beast deserves the murderer row look,
Old Jul 21, 2009 | 07:52 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
When I painted mine I sanded them down real good before applying any paint.
Old Jul 21, 2009 | 08:27 PM
mopardad68's Avatar
mopardad68
alone from sanding to bare metal what were the other steps, ie... cleaner,addhesive promotor and base color and clear coat, how many coats color and how many cleaar, thanks for the info and reply Brian Lee
Old Jul 21, 2009 | 08:30 PM
Off_Road_Teacher
Here you go man, this is the writeup I did of the whole process.
https://dodgeforum.com/forum/3rd-gen...20s-black.html
Old Jul 21, 2009 | 08:56 PM
mopardad68's Avatar
mopardad68
thanx, your Ram is the insparation for getting rid of non black parts, it is just stunning, and dont mean to be a bother. Brian Lee
Old Jul 21, 2009 | 09:08 PM
Off_Road_Teacher
No bother at all buddy. Let me know if you need anything else.
Old Jul 22, 2009 | 12:39 PM
cjs4444's Avatar
cjs4444
Yeah Man Teach's write up is money....i printed it out and had it with me......cant go wrong if you follow it....when do you plan on doing this.....dont forget to post some pics
Old Jul 22, 2009 | 01:38 PM
2005cobrakiller's Avatar
2005cobrakiller
haha u wish ur shi* was as black as mine....
I am currently painting my rims as well.... Because the covers are chrome remember to use a bit harsher of a sandpaper... I used 180 with a power sander for all the large surface areas and hand did all the small areas like the outside edge when you finish sanding there should be no reflexion in ur rim whatso ever.... I used soap and water to clean it all off then air dried it with a compressor then wiped it down with acetone.... then I used a tack cloth on it.... but i overdue everything....
