Lowered Trucks: tech and info....
Old Aug 5, 2010 | 03:55 PM
  #1461
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by astock
Red Truck- do you have an idea of how tall your front bump stops are? I was looking into changing mine also and I ran across some 1" tall bumps that I was going to order.
I cut the aftermarket bumps to be 1-5/8" tall.
http://www.summitracing.com/parts/ENS-9-9101R/
The OEM bump stop buckets are spot welded on opposite sides. I ground off the nearest side weld and drove a heavy screw driver under the bucket and broke it off. Then ground the weld off and painted the area.
Note: I first cut the bump to 1-1/2" and got a rub at extreme compression. With them at 1-5/8" I do not rub under any conditions.
Good luck....
Old Aug 5, 2010 | 06:32 PM
  #1462
astock's Avatar
astock
Thanks, I'll have to go order some 2" then and trim as necessary.
Old Aug 10, 2010 | 12:14 AM
  #1463
hemiAK's Avatar
hemiAK
hey so im ordering a 2" shackle drop for my 2006 ram 4x4 and i wanna get some helper bags for the rear so im not squatting all winter when pulling around the three place snowmobile trailer. so my question is when i put the shackle drop on is there a special helper bag i need like one for lowered trucks? or will i be fine with ordering just some regular helper bags?
Old Aug 12, 2010 | 09:03 AM
  #1464
tuned93's Avatar
tuned93
you'll be fine just ordering regular helper bags, id say get a heavy duty kit. something that can haul alot of weight (just to be safe), but most kits dont come with air. so if you want on board air then you'll most likely have to buy a compressor and valves seperatley
Old Aug 15, 2010 | 10:52 PM
  #1465
1500hded's Avatar
1500hded
I just installed my 2 inch drop shackles (McGaughys). I got a full 2 inches of drop (from 38 7/8 to 36 7/8). I already had Firestone helper bags. And after the drop there is no interference. Mine is RWD but I'm sure you won't have any problems on your 4x4. I haven't driven the truck yet. But I sure the ride will be better since I have new shocks on all 4 corners.
I forgot to deflate the bags before I started (the instructions for the helper bags mention to completely deflate the bags anytime the rear wheels are raised off the ground). So after I installed the shackles on my ride height was only about an inch of drop. But when I deflated the helper bags down she went.
Old Aug 17, 2010 | 10:09 AM
  #1466
mdeniz's Avatar
mdeniz
Just ordered my belltech 2/5 with ND2 Shocks...any words of wisdom?
Old Aug 17, 2010 | 10:16 AM
  #1467
BadHab1t's Avatar
BadHab1t
yeah drop it low, and take pics....glad to hear welcome to the dark side...
Old Aug 17, 2010 | 10:50 AM
  #1468
tuned93's Avatar
tuned93
ND2 shocks? do you mean N2D (nitro 2 drop) shocks? cuz if you do i will vouche for 'em, there good stuff! i have them on my truck. rides like a caddy, till i bottom out haha. ill get those helper bags on there when i get home
Old Aug 17, 2010 | 10:53 AM
  #1469
BadHab1t's Avatar
BadHab1t
hey you need to face me....got some good news for us florida boys...and what happened to you baggin it and me getting your drop kit...
Old Aug 17, 2010 | 07:10 PM
  #1470
herbito09's Avatar
herbito09
Default Nitrous Ram 1500
file:///C:/Documents%20and%20Settings/Owner/My%20Documents/My%20Pictures/7220_194434423664_502763664_3708488_3346195_n.jpg
file:///C:/Documents%20and%20Settings/Owner/My%20Documents/My%20Pictures/36676_456706148664_502763664_5803081_5340407_n.jpg
