Lowered Trucks: tech and info....
Old Sep 26, 2010 | 08:44 PM
  #1591
TXhemi5.7's Avatar
TXhemi5.7
Default New rims on the drop
Hey guys i got my new rims. MB KL 77 22X9.5" rims.
Before rims
After rims
Old Sep 26, 2010 | 08:47 PM
  #1592
BadHab1t's Avatar
BadHab1t
very nice i got a srt wingwhich is mounted, and new wheels 20" kmc stealths but i cant mount mine yet they need powder coating....and my rubber swapped on...
Old Sep 27, 2010 | 12:03 AM
  #1593
TXhemi5.7's Avatar
TXhemi5.7
Sweet man! show me a pic with the srt wing!
Old Sep 27, 2010 | 04:25 AM
  #1594
RedTruck-VA's Avatar
RedTruck-VA
Before rims
After rims
Truck looks great, however I prefer the OEM pedals....
Old Sep 27, 2010 | 09:47 AM
  #1595
MOusafLRT03's Avatar
MOusafLRT03
same here. i'll take those off your hands.
Old Sep 27, 2010 | 02:17 PM
  #1596
bigmac18's Avatar
bigmac18
OK, need a little help here.
I just installed a McGauphys 2/4 drop on my '06. (spindles up front)
I took it to get aligned and they said they had a hard time setting the caster correctly. they said I needed eccentric bolts for the upper control arms to be adjusted? From what I have read, the uca is supposed to remain stationary and the lower is the one that should be adjusted accordingly.
Has anyone else had this problem? Does this guy know what he is talking about? I went with the spindles instead of springs so I wouldn't have any alignment issues.
Thanks
Old Sep 27, 2010 | 07:19 PM
  #1597
RedTruck-VA
Thanks
MAc,
There is a lot of information in this thread, use the search function using "adjusters" and you will see most of it. I used adjusters and solved both a slight rubbing problem and alignment. And yes spindle drop keeps the suspension close to factory spec. Good luck.
Old Sep 28, 2010 | 12:04 AM
  #1598
lowlife916's Avatar
lowlife916
[quote=TXhemi5.7;2275058]Hey guys i got my new rims. MB KL 77 22X9.5" rims.
I think the wheels look great! Much improved.
Old Sep 28, 2010 | 12:14 AM
  #1599
lowlife916's Avatar
lowlife916
Thanks
I installed the same kit on my 07 1500 a couple months ago. I even drove it for a couple weeks on the old rubber and without an alignment before taking it in. I have a good alignment and tire shop that we use often at my body shop with customers cars. They installed new tires and aligned it no problem. I got a copy of the alignment spec sheet and everything is good, the steering wheel is straight and it doesn't pull. I would check with another shop before putting parts in.
Old Sep 29, 2010 | 09:46 AM
  #1600
bigmac18's Avatar
bigmac18
Thanks for the help, I think I'll try a different shop first and see if they can figure it out, then I'll look into the adjusters if necessary.
And, some Pics!
