Lowered Trucks: tech and info....
Old Dec 6, 2012 | 09:33 PM
  #1811
AD'S HEMI's Avatar
AD'S HEMI
Default left springs
ok peeps, i am about install these lowered 2inch shackles this weekends, i want to also remove the over load leaf spring, is it hard? Any help would helpful on this or the instructions would be better
Old Dec 7, 2012 | 11:53 AM
  #1812
DR360V8's Avatar
DR360V8
gotta watch the springs make sure they line up. i noticed with my springs that they are sagged from when i switched to the flip kit
Old Dec 10, 2012 | 09:36 PM
  #1813
AD'S HEMI's Avatar
AD'S HEMI
Default the rear dropped now
damn, it looks good to me, i will post pics.
so i installed the 2 inch drop with the shackle and removed the bottom spring on the leaf springs, and now may 26's look like 28's
pic coming soon
Old Dec 10, 2012 | 10:00 PM
  #1814
AD'S HEMI's Avatar
AD'S HEMI
so, i have a questions, i have read that adjusting the t bar in the front will lower the front end. where is the T bar, and will i need to get an aligment if i adjust it? if i adjust it, how much do i adjust it ? thanks in advance.
Old Dec 16, 2012 | 09:13 PM
  #1815
dk88's Avatar
dk88
so I lost a leg in the army lately.
stuck here with my 2002 dodge ram 1500, driving a wheelchair.
the truck is way to high to enter with comfort.
normal seat height is about 40 inches, I would need 20 inches less.
Is it possible to lower the truck that much?
while parking, the truck could lay on the ground, but ive never seen an airbag-system that could go this low.
maybe I should change to something different, but I love my truck...
Old Feb 25, 2013 | 01:46 PM
  #1816
BadHab1t's Avatar
BadHab1t
check out lowered ram trucks on facebook, you can get these trucks laid the eff out frame and all, then youll need your truck outfited for the wheel chair, there is a guy here in tampa with a brand new ram quad, he is in a chair also. he had his truck outfitted with a topper that lifts off to one side and has a crane to put his chair on the ground, hes lowered on 26s. what ever you want can be done just gotta pony up for the work. Im sorry for your loss, and thank you for protecting us. I salute you.
Old Mar 21, 2013 | 10:51 PM
  #1817
viperblueram's Avatar
viperblueram
Default Camber and caster help
Hey guys I have an 03 quad cab 2x4
I bought the eibach pro drop kit for the
Truck that comes with front coils and rear
Leaf springs. Now My tires are slanting in
Causing me to ruin my front two tires. The
Mechanic I took it to says he can only do
The toe in and out because the camber is
Already all the way out so he can't adjust the
Screw any further. My tires are REALLY loud
On the street even after aligning the toe. Any
Suggestions please?
Old Apr 10, 2013 | 01:06 AM
  #1818
coreycollier2's Avatar
coreycollier2
Lowered Trucks: tech and info....-my-truck.jpg
i wanna lower my 04 quad 5.7 hemi i have 22in rims but its higher in the back and i cant stand it...how low should i drop each to make it look good? i was thinkimg 2 in the front and 4 in the back
Old Aug 21, 2013 | 10:29 PM
  #1819
rosesinmay1980's Avatar
rosesinmay1980
Default Daimention of 2" drop shakles
Hi every body,
I need your help??
I'am going to modify my orgenal shakles to 2", So.
Any body have 2" lowering shakles, If it possible to send me it's daimentions??
The distance from the center of the boash hole to center of the leaf spring hole.
Or comperision Pics, between them.
Thank you all, and I appreciate your reply.
My Email: sadiqhameed@gmail.com
Old Sep 4, 2013 | 10:49 AM
  #1820
bigpete1125's Avatar
bigpete1125
I got a 6cyl ST 2wd so my front sat lower than all the V8's did anyways so I put a set of DJM lower shackles on the rear and truck looks lower and it's almost level now.
