Backseat A/C
Old Jul 26, 2009 | 10:54 PM
hemidel's Avatar
hemidel
I would really like to know if there is a way to do that. Would a fan look stupid clipped in the truck?
Old Jul 26, 2009 | 11:00 PM
96RamSLT's Avatar
96RamSLT
i never use ac... lol so i personally wouldnt attempt it.. plus my amp clogs up my seat..
but if im thinking correctly.. if u build it maybe 4 inches tall ... and somehow attach it to the frame of the seat, plus just make sure u have either stretchy plastic hose like slinky hose, or slack in ur hose so that can move with the seat a few inches... then just fit it into the hoses up front.. it should go just fine? just pipe connect it to the front lines.. now u wouldnt have a dual control **** or ne thing.. or u could i guess.. so its not like the grand caravan.. but hey man.. its air circulation.. and its cold..
Old Jul 30, 2009 | 08:30 PM
NoBlinger's Avatar
NoBlinger
A quad cab is really not that much space my kids are just as cold as I am in the front. Point the center vents right at them and turn it up. It's not like your trying to cool a warehouse or something. Use a sweet Elmo sun shade on the rear windows that might help. Don't forget the baby on board sticker!
Old Jul 31, 2009 | 11:08 AM
Spokane_Dodge's Avatar
Spokane_Dodge
+1
Center vents straight back, side vents straight down the sides angled up. Takes a little longer to get to the back but not much, after a few minutes on 3-4 Max AC the whole cab should be cold.
Old Jul 31, 2009 | 05:14 PM
96RamSLT's Avatar
96RamSLT
he said he wanted mad ac... thats what i was suggesting.. like i said.. i roll with tinted windows up with mild ac.. stays cool.. or windows down.. slider open.
Old Jul 31, 2009 | 05:43 PM
dirtydog's Avatar
dirtydog
Moderate User
Problem with this is, the air output is knida lame in the Rams to begin with. My fan screams while ouput is so-so. it's cold, but doesn't blow hard enough to channel through a tube under the carpet. My Exploder has back seat air but i am pretty sure it has an auxilary blower motor to be able to pull the air from the front to the rear.
besides, your from Seattle. All it does it rain ther and what's average temp. like 65-70 degrees in the summer?
Old Aug 1, 2009 | 01:20 AM
lxman1's Avatar
lxman1
Site Moderator
100 up there right now El Nino has struck.
A better idea than the dryer hose to the rear would be to hook up a a/c power inverter and put a small window unit a/c in a rear door window
Seriously, it would be a pita to try to tie into the ductwork to run rear vents. Maybe you could find a wrecked Megacab and remove the parts from it.
Old Aug 1, 2009 | 10:15 AM
bigmiah22's Avatar
bigmiah22
Unless you did a custome center console to run over the air housings its going to probably look pretty trashy.
Old Aug 1, 2009 | 11:15 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
How's the mega set up...are the ducts through the center console?
Old Aug 1, 2009 | 11:57 AM
Redone4x4's Avatar
Redone4x4
Originally Posted by Spokane_Dodge
+1
i agree with this.....i climbed back there the other day just to see. you could feel the air, my daughter says she can feel it all the time. the only problem we have is when the truck is full and an adult is sitting in the middle up front. then it does suck.
