Air intake
Old Aug 2, 2009 | 04:54 PM
gellin9o9's Avatar
gellin9o9
Default Air intake
Investing In an intake for my 06 megacab thinking of a true flow intake uses a foam filter and produces like 29 hp but I'm not really to sure about using a foam filter anyone using one of these kits or have any suggestions on this or any other one thanks
Old Aug 2, 2009 | 05:08 PM
disturbedgator's Avatar
disturbedgator
get a ebay kit, put a high dollar cone filter on the end and call it a day, unless you get a bfi there all the same
Old Aug 2, 2009 | 06:21 PM
chambers's Avatar
chambers
As long as the foam is thick enough it should filter well, at least an inch thick like in their demo video should do well. I have a true flow filter on my spectre intake and plan on getting a used oil analysis to check it's dirt stopping ability. S&B tested a true flow filter made for a diesel on there site http://thetruthaboutfilters.com/ and it did poorly, but I believe it was b/c the foam wasn't thick enough in that case. There are tests for all the major brand filters on S&B's site so check them out.
Old Aug 3, 2009 | 09:30 PM
gellin9o9's Avatar
gellin9o9
Default Intake
That s&b intake looks cool and it's priced right any one have one of these installed on their trucks
Old Aug 3, 2009 | 10:00 PM
RubberFrog's Avatar
RubberFrog
Get one of the two top intakes, or don't waste your money.
Old Aug 3, 2009 | 11:28 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
29hp from a CAI...only if you have a dead kitten in your stocker.
Old Aug 3, 2009 | 11:44 PM
draco8494's Avatar
draco8494
you get alotta sound and a little bit more kick but not 30hp worth, i had an egay intake with a K&N did good for the money,...
Old Aug 4, 2009 | 12:21 AM
98cherryram's Avatar
98cherryram
The airaid was actually the best combination of airflow and efficiency.
Old Aug 4, 2009 | 12:24 AM
98cherryram
This is what I want, http://www.sbfilters.com/products/pr...r=78-1403-S-PC
