3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hi i am new here and i just bought a 04 ram1500 and i was wondering what wieght oil to use i put 10/40 wieght is that ok.
Use what ever is recommended by the factory for the engine. BTW what engine are we talking about??HEMI, 4.7?? If its the Hemi the 5w20 is recommended and thats what I run. The recommended weight should be in the Owners manual or if you don't have one then it should be on the oil cap.
Sorry it is a 5.7 hemi and the oil cap says 5-30 wieght
Well I have an 05 non MDS and my buddy has a 04 non MDS, both Hemis and both call for 5w20. But I would run what ever the oil cap says or the Owners manual.
Do you guys use reg oil or sysnt? I put what the cap says on 04 ram1500 5.7 which is 5/30 wieght but i hear a ticking is this normal i only have around 48,000 miles on it.
Sounds like the hemi tick, search around it's pretty common and not a sign of a problem. Some say royal purple helps w/ the hemi tick but it's kinda pricey, pennzoil platinum is also an excellent choice for synthetic.
