White stuff on oil fill neck?
Old Mar 26, 2005 | 09:04 PM
adamsredlines's Avatar
adamsredlines
Default White stuff on oil fill neck?
I did an oil change today, i'm at 15k miles, and there was white gunk all over the cap and the little part that fits into the neck. Is that normal? It almost looked like grease. I took a pic and will post it a bit later, until then, any suggestions? The first few oil changes were done at Dodge, after that I switched to Mobil 1, is that a characteristic of synthetic?
Old Mar 26, 2005 | 09:14 PM
adamsredlines
Default RE: White stuff on oil fill neck?
Old Mar 26, 2005 | 10:57 PM
IS_THAT_A_HEMI's Avatar
IS_THAT_A_HEMI
thats what it looks like when water is in your oil....
[IMG]local://upfiles/11020/195DF4F015D942C9909869023570A415.jpg[/IMG]
Old Mar 26, 2005 | 11:14 PM
Deviousin10tions's Avatar
Deviousin10tions
yup water
Old Mar 26, 2005 | 11:16 PM
adamsredlines
Peachy...what should I do to fix it? I let all the oil drain out today, is there something else I should/can do?
Old Mar 26, 2005 | 11:40 PM
Hemi Dave's Avatar
Hemi Dave
You need to get it back to your dealer. Apparently your PCV system has failed or something more major such as head gasket, crack in block or head. Bottom line you have water getting in your crank case or for some reason condensation is building up inside your engine. If you drive your truck each day you should not have condensation unless something is wrong. Very bad situation because you are washing down your bearing, etc. with a mixture of antifreeze and water. Please let us all know what they find.
Dave
Old Mar 27, 2005 | 10:39 AM
alienyzf's Avatar
alienyzf
This happens when you live up north and you don't let you truck warm up in the winter before you drive off on short trips. Warm truck up thoroughly and immediately change oil.
Old Mar 27, 2005 | 12:14 PM
ce2flaco's Avatar
ce2flaco
Alien has a great point. I had the EXACT same problem with a pontiac and a chevy while living in Wisconsin. Never had a bad head gasket. It was just condensation. Both cars went well over 100k before i sold them. Either way i would take it to the dealership and take your pics with you. See what they say and keep an eye on it.
Old Mar 29, 2005 | 03:26 PM
Heavy Date's Avatar
Heavy Date
I get the same thing in both my Ram and Durango. Most people up here in the north have the same thing.
Old Mar 30, 2005 | 05:34 AM
2004 Hemi Quad's Avatar
2004 Hemi Quad
How long do you run the truck each day. Short trips in cold weather will cause that kind of problem.
