Did we just make a huge MISTAKE... please help
Maybe it's going from an explorer to a ram with 20s? My truck came with 17s and it rode great. I then moved up to 20s and i felt the wheel jerk on every single bump. I changed my computers tire setting with my super chip which improved it; but it is still a rougher ride than before.
I can't for the life of me figure that one out???
Al
Got Hemi, I just now realized your from the Gem city, Hell we are practically nieghbors.
P.S. I'm not sure what your referring to on changing tire settings with your tuner to effect ride quality but,Oh well I'm just glad to see another Buckeye on here.
I just bought a 2006 1500 5.7 32000 miles and the front struts were leaking (I picked up on them leaking when I first looked at the truck) I had the same uneasy ride and replasced them with Monroe/Gabriel units and the ride is 150% better! Look for oil leaking at the top of the strut housings!
HTH
Richard
HTH
Richard
If you are new to pickups in general, going from an explorer to a truck will take a little getting used to. That being said, our trucks should ahve a firm but comfortable ride. I have driven pickups with poor shocks over dirt roads and have experienced what you are describing. Shocks are a definite possibilty.
I have something for you to try. It may help. New suspension can take time to break in---or settle---. Go to Lowe's or Home Depot and get 3-4 80lb sand tubes (or the equivalent), and put them in the bed, centered over the rear axle. Then take the truck for a drive. See if that helps.
This pre-loads the rear suspension, and takes it off its normal "empty" condition. I believe you will find it rides much smoother, and balances the the rear to front weight a little better giving you better handling.
I know you shouldn't have to do this with a fairly new vehicle, but, regardless, it really seems to help---especially if you're not accustomed to a "pickup truck" ride.
Not sure what everyone's talking about the 20's or the Goodyears. I went from my stock 17's with the Michelins (later got some Les Schwab tires) and now I have 20's with Goodyears, and I didn't notice a change in ride with any of them. My truck rides as smooth as my wifes Kia...except for the bigger bumps. The rear tends to kick out just a bit sometimes.
