help pleeeease!
Old Aug 16, 2009 | 12:42 AM
bloodySUNDAY134's Avatar
bloodySUNDAY134
Default help pleeeease!
having an issue with my '08 ram. when i'm in drive and my wheel is cranked, like say when i'm waiting in a drive-thru, i get a weird noise that sounds like a fan belt squeak. when i turn the wheel the other way, the noise stops until its cranked the other way. after cranking it back and forth a few times, the noise seems to go away. it only starts up again after the truck is restarted after sitting awhile. any ideas on what the noise could be?
Old Aug 16, 2009 | 01:02 AM
tuned93's Avatar
tuned93
sounds like belts to me. are they tightened to specs?
Old Aug 16, 2009 | 01:07 AM
OklaHemi's Avatar
OklaHemi
maybe power steering. is it hard to turn at all? check your fluid level
Old Aug 16, 2009 | 01:12 AM
tuned93's Avatar
tuned93
if it were power steering you'd be hearing a slight "whine" kinda like a supercharger
Old Aug 16, 2009 | 01:17 AM
OklaHemi's Avatar
OklaHemi
i know but a squeak could be a whine. depend on who you ask
Old Aug 16, 2009 | 01:25 AM
tuned93's Avatar
tuned93
ahhh!! tomato taMAto right...
Old Aug 16, 2009 | 10:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
But turning it to the point where it does whine and causing to much pressure on it could make a loose belt squeel. I think you need to pop the hood and have another person with you and do it to see what is making the noise.
Old Aug 16, 2009 | 05:14 PM
bloodySUNDAY134
thanks guys. i'm not really mechanically savvy, but i'm pretty sure it's not the power steering. it's not hard to turn at all and doesn't have a whine. i've had belt issues before in previous vehicles i've owned and this sounds very similar to that. i'm going to bring it to the dealer tomorrow to see what the deal is. i just hate bringing it in for service because i have to take the programer and tune it back to stock.
Old Aug 16, 2009 | 08:58 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well be sure to let us know what they say it is.
Old Aug 16, 2009 | 09:06 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
that's your power steering. do it a favor and STOP cranking the wheel all the way, they hate that. even if you need to make a tight turn, don't crank it if it's at all avoidable. that's all normal though.
