2007 leveling kit help
Old Aug 16, 2009 | 12:22 PM
DaytonaDakota's Avatar
DaytonaDakota
Default 2007 leveling kit help
i am leveling my 2007 dodge ram 1500 and im a little confused, ive taken everything apart but it seems like the a arm is still wanting to stay connected . basically is there anyone out there that can explain how to install the leveling kit or are there any sites that show step by step instructions. any input would be great thanks
Old Aug 16, 2009 | 12:44 PM
santafehemi's Avatar
santafehemi
here is a dyi for a 4x4 not sure if yours is 4wd or 2wd hope it helps
https://dodgeforum.com/forum/3rd-gen...dbeardmcg.html
Old Aug 16, 2009 | 02:49 PM
RubberFrog's Avatar
RubberFrog
What exactly is holding you up?
Remove the nut connecting the sway bar to the sway bar end link. Remove the three nuts from the top of the strut. Remove the nut for the upper ball joint. Hit the side of the spindle with a bfh. It might take a few wacks until the ball joint separates from the knuckle. . Remove the bottom bolt attaching the strut to the lower A arm. Squeeze the strut coils until you can slip it off the truck. Install the spacer. Reinstall the strut. Put it all back together. Go get it aligned.
