Should i get different CAI???
Old Aug 18, 2009 | 03:19 PM
dunerider650's Avatar
dunerider650
Default Should i get different CAI???
Right now i have a drop in k and n filter in the stock box and i replaced the "Hemi Hat" with 3" pvc pipe from the box to throttle body...i also cut the sides out of the bottom of the box for more air flow...the 3" pipe has a few bends in it to line up to the throttle body and it seems to run good...makes a hell of allot of noise and is never hot after a drive... my question is would getting a 4" filter and running 4" pipe in a straiter line to the throttle body with a open cone filter equal greater results and maybe less noise??? or should i spend the time on replacing my y pipe in the exhaust???
Old Aug 18, 2009 | 05:59 PM
chambers's Avatar
chambers
Your money is better spent on your exhaust at this point.
Old Aug 18, 2009 | 07:17 PM
draco8494's Avatar
draco8494
x2 with exhaust... you can only do so much with ur intake, and what you have is a good setup, i might go back to having my drop in and filter box to keep it from getting so dirty and wet if i hit deep puddles...
Old Aug 18, 2009 | 08:49 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
x3 on the y
Old Aug 18, 2009 | 11:08 PM
TRXHemi's Avatar
TRXHemi
Ya got any pics? I was thinking of going back to my airbox with a pipe to bypass the hat...
Old Aug 19, 2009 | 07:47 AM
V10Venom's Avatar
V10Venom
+1 on the pics!
Old Aug 19, 2009 | 06:39 PM
dunerider650
Originally Posted by V10Venom
+1 on the pics!
when i get to work tommorow i will upload pics on my phone now i just want info on what u guys think of the flow and the bends
Old Aug 19, 2009 | 06:53 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Would have to see the bends. Did you use any 90 degree elbows? I think that that would have some effect on flow using a 3" pipe. If you are that worried, you can get just the tube and have that replaced. The filter job that you have done, seems pretty good. You are already getting more air into the box, now you just have to make sure you are getting that air to the engine.
As far as the noise goes, there will be no difference if you change to an actual CAI or not. IMHO, I would look into the exhaust now. You are getting the air in, now you have to get the air out.
Once you get some pics posted of your homemade intake, we can critique it then.
Old Aug 20, 2009 | 12:10 AM
billnflorida's Avatar
billnflorida
any particular spot on the filter box that you cut away.......
Old Aug 21, 2009 | 10:11 AM
dunerider650
All of the sides and yea i know its prob gonna suck in some hot air....wish i would of thought a bit more before i cut it....but shes getting allot of air atleast....heres a pic let me know what you guys think.
