DIY for tranny fluid and filter?
Old Aug 18, 2009 | 06:06 PM
Bluesmanjesse's Avatar
Bluesmanjesse
Default DIY for tranny fluid and filter?
I was looking to see if there was a diy for the tranny fluid and filter change on a 3rd gen, I have yet to pick up a service manuel yet for my truck. I couldn't really find a DIY all I really need personally is the tourque spec for the pan bolts but I am curious if anyone has posted a DIY yet? Thanks in advance!
Old Aug 18, 2009 | 06:09 PM
truckin151's Avatar
truckin151
Couldn't tell you about the tq specs but I just did mine 2 weeks ago when I did the tq converter.
Old Aug 18, 2009 | 06:17 PM
truckin151's Avatar
truckin151
Just remember that there are 2 filters in the pan, and the flat one of the two is a different shape depending on if you have a 2wd or 4wd truck.
Old Aug 18, 2009 | 06:45 PM
sudnit5's Avatar
sudnit5
There sure is...
http://www.60ateight.com/DodgeRam/
Old Aug 18, 2009 | 07:09 PM
MikeHTally's Avatar
MikeHTally
Pan bolt torque specs: 105 in/lbs (at least for an '03). As you may know, you'll need lotsa newspaper. It's a messy job, but easy enough.
Old Aug 18, 2009 | 08:09 PM
Bluesmanjesse
I made sure to get the right filter for 4wd as well as the spin on one,I think I'll pick up a haynes manual just cause I need one anyways. Thanks Guys!
Old Aug 18, 2009 | 09:49 PM
shadow11's Avatar
shadow11
Here is the DIY I followed when I changed my tranny fluid http://www.60ateight.com/DodgeRam/
Old Aug 18, 2009 | 10:13 PM
Bluesmanjesse
Shadow thanks, Did you happen to read sudnit5's post 3 posts above yours?
Old Aug 18, 2009 | 10:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And I tell you now as I read and seen where guys snapped those pan bolts. I went to Lowes and got Grade 5 replacement bolts and didnt snap a single one going back up. You will need a mechanics pick set (comes in a pack of 4 diff hooks for about $10) to get that one o-ring out for the flat filter. You will need a set of fuel line quick disconnects for theat trans line up by the radiator also. To do the pan and trans it is 17qrts
Old Aug 18, 2009 | 11:07 PM
shadow11's Avatar
shadow11
Nothing came up when I clicked on his link so sorry if I posted the same thing.
