Problem - Starts fine, then stalls
My '07 1500 5.7L has run great since I purchased it over 1 year ago. I have not had a single problem until this morning.
I get in, turn the key, and it fires right up, then dies. I've never had this happen before. Crank it again, starts fine, dies. Tried it 3 times. Same results. When it dies (stalls), the "Check Gauges" light is on, but that's it. It started and cranked completely normal. I even tried to hit the gas (which I never do when starting) to get the RPMs up, and I made it to 2k before it died.
I replaced the spark plugs and cleaned the throttle body about 2 months ago (900 miles ago) and everything worked great until this morning.
Thoughts?
Thanks in advance!
joe
Thoughts?
Thanks in advance!
joe
Ugh.... ok... what's the best way to test this hypothesis. I know the filter and pump are in the gas tank. Should I just attempt to pull the tank (I really don't know what's involved in that process yet) and check the screen? I really hate to pull the tank, clean the screen, get it all back together, only to find out that the pump is shot.
joe
joe
Ouch.... $200 for fuel pump. So I have never used the warranty on this truck. I believe it is still under the 3 yr 36k mile warranty (although just barely). Since it's stuck in my driveway, would Dodge pay a towtruck to come get it and check it out? Again, if it's just the filter, then I'm sure I would end up paying for it. If it's the pump, it should be covered under warranty, right?
joe
joe
Trending Topics
Yes it would die in park. I could start it and it would stall. I gave it some gas while starting with my foot on the brake and I could keep it running. Check Gauges light comes on, and it keeps stalling any time I stop at a light. I ended up coasting into the dealer - they had to replace the trans.
