Got my SC 3815, what do you guys think of these numbers?
Old Aug 25, 2009 | 04:21 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by ttam7777
Is the tow tune better than the performance tune? If so, why? More torque and different shift changes...?
From what I have read it is the same as the 91 tune but with less timing in it. I think I saw that in the SC sticky but I am not positive.
Old Aug 25, 2009 | 05:59 PM
Pyro's Avatar
Pyro
I Beat Tetris
The tow tune is pretty much the same as the 91 performance tune as far as the engine is concerned, just slightly less timing advance. The tow tune also "tames" the shifts so at WOT you don't get the lurching the performance tune has. I've noticed the tow tune also guzzles more gas than the performance tune.
Old Aug 25, 2009 | 06:11 PM
truckin151's Avatar
truckin151
Never really played with the towing tune when I had the sc, I mainly did the 87 and 91 and got the best results with the 91 performance tune.
What was the temp out when you did your run, what elevation are you? 1/4 mile in 16.2 / 0-60 time in 7.8 sounds a little slow for not having any tq management and 3.92's.
Old Aug 25, 2009 | 06:16 PM
cheapbeater's Avatar
cheapbeater
elevation here is about 1200 feet, temp was about 80 and kinda humid... hopefully the numbers will be better after i have the right gas in...
