A lot of Spacing between bumper and Headlight
Old Aug 25, 2009 | 11:24 AM
espinosafell's Avatar
espinosafell
Default A lot of Spacing between bumper and Headlight
I was wondering I noticed I have a lot of spacing between my drive side bumper & headlight.... I was wondering can I fix this by moving the bolts a bit...
Old Aug 25, 2009 | 11:59 AM
CNFD's Avatar
CNFD
Not sure about a fix, but I wish I had that much space when trying to get out my headlights. That 3rd bolt would of been a snap to get out!
Maybe theres so much space due to someone trying to get to that 3rd bolt?
Old Aug 25, 2009 | 12:27 PM
RubberFrog's Avatar
RubberFrog
Loosen the 4 bumper bolts, lift up the bumper, retighten.
Old Aug 25, 2009 | 12:35 PM
espinosafell
Perfect that is exactly what I wanted to here... The bolts are simple to get to correct... And Is there pictures around the forum?
Old Aug 25, 2009 | 12:58 PM
OklaHemi's Avatar
OklaHemi
yes the are easy to get to, right on the frame. 18mm by the way
Old Aug 25, 2009 | 01:13 PM
espinosafell
Perfect you guys are great!! Im a computer engineer not a auto engineer, but wish I could switch... cause my truck is fun to work on now...
Old Aug 25, 2009 | 01:42 PM
astock's Avatar
astock
This is great news. I have to adjust mine a little bit also. My passenger side is low and my drivers side is tight against the light.
Old Aug 25, 2009 | 01:48 PM
espinosafell
I have the same exact problem going to fix that right after work but vice versa on sides...
Old Aug 25, 2009 | 04:04 PM
OklaHemi's Avatar
OklaHemi
if you can have someone with you to eyeball it and tell you when you are good. that way you wont have to crawl under the truck 4 or 5 times.
Old Aug 25, 2009 | 04:30 PM
espinosafell
Haha yea I already found an assistant ...
