04 qc cam swap advice!!!
Old Aug 25, 2009 | 06:05 PM
NjRaM's Avatar
NjRaM
Exclamation 04 qc cam swap advice!!!
Alright guys i want to upgrade the cams, and getting a Tc with the setup. My question is what cam setup would be best for my 04 Ram, and what problems do i have to worry about when i upgrade my cams? what i mean is will it throw some DTC's codes or will it make me fail inspection? I just seed some imput because this will be my first time ugrading cams....Help me out!!!!! I was on moesperformance.com and i was looking at the "crazy jays" setup but i just want to make sure i'm making the right choice....Setup aint cheap.
Old Aug 25, 2009 | 06:15 PM
HammerZ71's Avatar
HammerZ71
well it's a Hemi, so it's singular - CAM.
Depends on your use, and how aggressive you want to go. But any cam that is gonna do anything for a heavy QC 4x4 is gonna require a tune.
The only real cam choice for you (and no, the 6.1 Hemi cam would be lousy for all but RCSB 4x2s) would be a Comp 260, can get by with all the other stock parts, although I'd personally opt for stronger springs and can be tuned with a SC or canned Diablo tuner. Anything much more aggressive than that and it's custom tune and I think if you alter the A/F ratio, you run the risk of failing inspection. Dunno, maybe someone from an inspection state with a cam upgrade will chime in...
Old Aug 25, 2009 | 06:19 PM
NjRaM's Avatar
NjRaM
I am going to upgrade the springs and rods but you think with my mods the 260 would be the best? Will there be noticable gains in the Hp.
Old Aug 25, 2009 | 06:25 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
If you want a production cam that is more agressive than the 260 but will still run on a canned tune from a SC you could go with the Sidewinder. It is a good cam with strong torque down low while still giving good power in the higher RPM range. Very good cam for a heavy qc 4x4. Or you could always contact one of these cam vendors and get a custom grind done to fit your exact needs and mods.
Old Aug 25, 2009 | 06:27 PM
truckin151's Avatar
truckin151
You can also go with the spartan cam as well. You also need to do something a bout a tuner as well because the spartan will require a custom tune and upgraded internals (springs/rods). The crazyjay cam is a mellow cam and can be ran with little to no problems with a standard tuner, although an actual tune will net you more gains than a canned tune will.
Old Aug 25, 2009 | 07:26 PM
04-fourseven's Avatar
04-fourseven
My number one piece of advice is to have somebody else install it. lol. Good luck with your shopping, and let us know what you come up with
Old Aug 25, 2009 | 08:00 PM
NjRaM's Avatar
NjRaM
I looked at the spartan cam but for what im looking for it might be alittle too aggressive..I'll be wasting WAY too much money on gas with that upgrade...lol thats why i looked at the smaller cams....04-fourseven i aint going to install it, it would take weeks..lol my bro in law is a mechanic. he's the one doing the work. i will def. post when i choice and install the cam's...hopefully within the next week...
