Gas mileage has tanked... ????
Old Sep 8, 2009 | 04:49 PM
  #31
bwhite757's Avatar
bwhite757
Originally Posted by EASTTEXASDODGE08
well since ive gotten my truck only couple months ago, i get roughly round 14 or 15 mpgs with the 4.7. ive been looking for a way to increase mileage and need help asap. do the hemis get better mileage than the 4.7
The 08 4.7 is a different beast than older models. It's more fuel efficient, and a lot more powerful. It gets as good or better mileage than 08 and older hemi's, I believe the 09 Hemi's mileage is back over that of the 4.7. That said, with a 4x4, 14-15 mpgs is to be expected, and probably won't see much of an increase past doing everything that was told to me on this thread... City driving is a mileage killer, and if you're not almost 90% highway, then I wouldn't ever expect higher numbers than what you're seeing. It takes a lot of juice to get the the beast going from a dead stop.
Old Sep 8, 2009 | 05:17 PM
  #32
gmb4fords's Avatar
gmb4fords
yea city driving kills me as well. i avg 15 thats about 50 50. and my throttle body was nowhere near that bad lol but it was dirty.
Old Sep 8, 2009 | 05:29 PM
  #33
bwhite757's Avatar
bwhite757
Really?? I've pulled mine off at 20k intervals and it's been that bad every time.. Hmmmm... Maybe I need to check something else....
Old Sep 9, 2009 | 02:04 PM
  #34
bwhite757's Avatar
bwhite757
Pleased to report that it appears my mileage is back to normal. Drove home from work after installing the EGR valve and back to work today. Overhead economy is reading 21.7 mpg's, which normally comes out to be around 18.5 at the pump. Truck is running great... Now it's time for another mod that has caught my fancy... Time to find a Taurus efan to install into my truck...
Old Sep 9, 2009 | 05:12 PM
  #35
Ridinhigh's Avatar
Ridinhigh
how much does an EGR vavle cost to replace because after reading this this is something that I would like to do as well as clean the throttle body any tips on how to get it clean
thanks
Old Sep 9, 2009 | 07:54 PM
  #36
Bluesmanjesse's Avatar
Bluesmanjesse
Ya, I'd like to know how many $$$ an EGR valve is also? Thanks
Old Sep 9, 2009 | 07:59 PM
  #37
Off_Road_Teacher's Avatar
Off_Road_Teacher
EGR is about $40.
Old Sep 10, 2009 | 12:03 PM
  #38
bwhite757's Avatar
bwhite757
If you guys aren't throwing codes, I would try cleaning EGR valve first. Soak the entire bottom of the valve in carb cleaner or gas, keeping the top (electronics) dry, pull it out wipe it down, let it dry, move the valve mechanism up and down to make sure its fairly loose, and throw it back on the truck. The one that came off my truck was stuck open, I took it and spent a few hours cleaning it, and it's clean and seems like it would work again if I need it. I take my TB off every 20k to clean it, I think I'm going to start taking the EGR valve off as well and clean it the same time...
Ridinhigh: do a search around for egr valves, or "P0406". Depending on what date your truck was produced, if you swap the EGR, you may have to reflash your computer. They changed to design on the EGR valve mid 04, and requires your computer have the new setup....
Old Sep 12, 2009 | 12:21 AM
  #39
myoukey's Avatar
myoukey
You will have to let me know how that works for you... The more I hear about the “e fan” the more curious I become. Would like to know what effect it actually has, where you got it (when/if you do) and how you installed it…
Old Sep 12, 2009 | 09:01 PM
  #40
Off_Road_Teacher
The Taurus fan works great. It cools the engine without a problem on the low speed and eliminates the parasitic loss associated with the clutch fan. Getting one is pretty easy, you can get it at pretty much any junkyard for around $20 or from eBay for a little more. Install is straight forward, maybe two hours start to finish.
