Custom Air Intake
Old Sep 9, 2009 | 01:26 PM
  #21
chambers's Avatar
chambers
Originally Posted by Shiloh 24
Any suggestions of how to keep this from happening again other than not driving through deep water.
Get one of the water resistant prefilter covers like this one http://www.autoanything.com/air-filt...A2582A0A0.aspx it should help, but it's no guarantee.
Old Sep 9, 2009 | 01:40 PM
  #22
bwhite757's Avatar
bwhite757
I couldn't imagine how water would get to your setup unless you drove through a lake. I've driven mine through some pretty bad storms and flooded roads with no problems. The first couple of time I always checked to see if the filter was wet after I got done driving, but after checking it 3 or 4 times and it being bone dry, I stopped worrying. Mine's been on my truck now almost a year with no problems..
As a reply to an earlier statement on it being a "Hot Air Intake" if it doesn't have a heat shroud, according to my Edge tuner my stock intake would normally run 30-40 degrees above ambient air temp. I did see it get almost 50 degrees above 1 time. With my DIY CAI it averages about 10 degrees above ambient, and the hottest day this Summer I was out driving, Ambient temp was 103, and my IAT sensor was reading 115 driving down in the city..
My setup:
Old Sep 9, 2009 | 01:49 PM
  #23
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
how the f did you get water in there? I wonder if it came over the top between the hood and the fender instead of from below.
Old Sep 9, 2009 | 02:31 PM
  #24
Shiloh 24's Avatar
Shiloh 24
It was wet it was dripping when i got home. The top of the wheel well was wet as well and pretty much everything under the hood was soaked.
Old Sep 9, 2009 | 02:37 PM
  #25
bwhite757's Avatar
bwhite757
Well, if you drive through a deep enough puddle, you can even suck water in through a stock air box. Sounds like it might have been an isolated incident. I say leave it alone for now, and see what happens the next time you drive it in the rain. If it's a good downpour, when you get home or somewhere you can check it, see if it's wet again. If so then you need to figure something else out...
Old Sep 9, 2009 | 02:55 PM
  #26
Shiloh 24's Avatar
Shiloh 24
But I did hit the water at about 40 mph so that my explain the crazy amount of water all over everything. I might try that filter cover though.
