Blown Head Gasket
Old Sep 7, 2009 | 05:16 PM
  #41
countrygirl4X4's Avatar
countrygirl4X4
yeah the problems started about a week after that- but like i said the mechanic said he thinks they were unrelated since i had no water in my oil?
he thinks that my thermostat got stuck- but we shall see.
i talked to the dealership today- they said that since i'm not having it done at their shop that they won't help with the labor cost- but that they will see what they can do about everything else, i just have to send them an invoice.
if i hear one more time that they will 'see what they can do' i may go crazy.
Old Sep 7, 2009 | 05:32 PM
  #42
chambers's Avatar
chambers
Kinda strange that the t-stat would just get stuck one day, but that seems like a good explanation. If just the radiator was clogged I imagine it would take a little longer to overheat. Either way it's a good idea for anyone who owns one of these trucks to change the coolant at the recommended 5 year/100k mile interval to prevent corrosion which can lead to overheating. I really think the dealer should cover this under their warranty, and they should pay for it to be done at a Dodge dealership. Good luck.
Old Sep 7, 2009 | 05:41 PM
  #43
dirtydog's Avatar
dirtydog
Moderate User
A T-stat is considered "internal engine components" in my books so that would mean, your warranty would cover the damage?????
Dealers will tell you anything to get you out the door without actually commiting to fix the problem on hand. Seems like your gonna need a lawyer to get them to reimburse you.
Again, i would report them to the BBB if they give you a hard time when all is said and done.
Old Sep 7, 2009 | 09:59 PM
  #44
Docwhitley's Avatar
Docwhitley
First ... Sorry to hear about your truck... but pulled up some info I gathered through the years in the car business... Please understand that you will need to verify this info... but I think you were in California and this is what I had for that state
Used cars that are bought for at least $3,000 are required to be repaired and serviced for free from the dealer for a minimum of 60 days or 3,000 miles depending on which one of these conditions is reached first. Used cars bought for less than $3,000 are required to be repaired for free from the dealer a minimum of 30 days or 1,500 miles depending on which one of these conditions is reached first.
Now if they said all internally lubricated parts and did not specify what was covered... Well they screwed up, but more than likely there was a sheet in the window "buyers guide" that would list the specific components that are covered. Ask to see this form. It will list the parts covered in the "inclussionarry" warranty. Check the law in your state regarding the required warranty. In my state I can not dictate where you get the car repaired
Old Sep 7, 2009 | 10:08 PM
  #45
Docwhitley's Avatar
Docwhitley
Just looked again... and you are in NC
Did he have in the paperwork you signed
as is
with faults
and did you sign the FTC or buyers guide?
This will decide if you really have any shot here in your state
Old Sep 7, 2009 | 10:26 PM
  #46
countrygirl4X4
my buyers guide states that i've got the 30days 1000 mile warranty
internal lubricated parts of the engine and tranny and that the work must be done at their shop. (they cover 50% of labor and parts.)
it also says that by law i may have rights by 'implied warranties'
Old Sep 7, 2009 | 10:28 PM
  #47
countrygirl4X4
and i just looked at my miles at the time of purchase
and the miles when it went into the shop.
im about 300 miles over my warranty.
awesome.
fml.
Old Sep 7, 2009 | 11:19 PM
  #48
05RamMan's Avatar
05RamMan
Just in case anyone cares, This is the all data chart on that. Really you should have to worry about the one bank. If your lucky there is no warpage. I have never done any headgaskets on the 4.7 but I have fixed a few on different vehicles. Usually with all the correct tools, it only takes me 3/4 the stated time and thats with beer brakes.
Another option I havent seen On here that I have used with great success is that $8 can of gasket fix they sale at walmart. I have seen the stuff last 100K miles before anymore issues arrived. However it is very particular on how you use it, Absolutely no coolant can be in the system when you goto use it.
