Traction Control - turn it off
Old Sep 6, 2009 | 01:01 PM
Ramcycle's Avatar
Ramcycle
Default Traction Control - turn it off
2008 Dodge Ram with a 4.7 V8 and 6 speed manual: It is factory programmed to eliminate all forms of engine braking as part of its traction control. This, obviously, makes it annoying to drive. How can I turn it off? Or better yet how can I switch between NORMAL engine/power train management and the factory TRACTION CONTROL which is needed only for slippery roads when it gets icy.
This would be a good feature for SuperChips, Diablo, HyperTech or someone to market.
PS: The 200ms delay in the throttle stepper motor is NOT the problem.
Old Sep 6, 2009 | 01:28 PM
dirtydog's Avatar
dirtydog
Moderate User
pull out the fuse that controls it.
Old Sep 7, 2009 | 10:01 AM
Plainbroke's Avatar
Plainbroke
Isnt that going to throw a code?
Old Sep 7, 2009 | 10:17 AM
dirtydog's Avatar
dirtydog
Moderate User
so what if it does? It solves his problem.
besides, it won't 'throw a code" it may illuminate a light on the dash as if it were activated. Same type of teeny light as the seatbelt guy, or abs light, or any other light.
It's a quick easy solution so the guy can burn up the rubber and do as he pleases. It won't create any driveability problem. Heck, i drove my silverado around with the 60amp abs fuse pulled because it activated way to much for me. i pulled the bulb cuz i was sick of looking at it. never had any problems and drove it like that for 4 years
Old Sep 7, 2009 | 01:28 PM
lxman1's Avatar
lxman1
Site Moderator
They designed it to not engine brake on dry pavement? That doesn't sound right.
I have never driven one to verify, but it doesn't seem right at all.
