Whats the additive called?
Old Sep 7, 2009 | 08:01 PM
Toyman's Avatar
Toyman
Default Whats the additive called?
Whats the additive called they put in the rear end to stop the shimmy (for lack of a better word) when making a turn? 2003 Ram
Old Sep 7, 2009 | 08:48 PM
cheapbeater's Avatar
cheapbeater
i think they call it friction modifier additive. did you change the fluid without adding the friction modifier? or has it just started doing it out of the blue?? if so, you should probably change the fluid and check out the rear...
Old Sep 7, 2009 | 09:58 PM
HammerZ71's Avatar
HammerZ71
Yes, it's friction modifier and should be added every 30k miles when you change the diff fluid, 15k if you tow or haul...
