Old Aug 5, 2015, 09:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
disconnect chime for lamp out on dash
Old Sep 24, 2009 | 09:17 AM
big_kahuna's Avatar
big_kahuna
I've run into the same problem with the lamp out coming on/off for week or so before the bulb actually goes out. My problem is that I've changed out the same bulb twice in the last year. Now it's gone out again. It's the Left rear brake light. What's odd is that this is a 2 element bulb and one element never burns out, just the one element for the brake. When i've changed it out in the past the socket looks good and it's a snug connection. My question now that it's happened again, is this a wiring issue or possilbly something within the piece that the 3 rear bulbs plug into. Any ideas?
Thanks!
Old Sep 24, 2009 | 09:27 AM
dirtydog's Avatar
dirtydog
Moderate User
have u checked your 3rd brake light bulb?
Old Sep 24, 2009 | 09:38 AM
big_kahuna's Avatar
big_kahuna
yep, actually just had a guy I work with go out with me and pump the brakes. It's the same left rear brake again. signal lights work, 3rd brake, plate lights all look good.
Old Sep 24, 2009 | 10:11 AM
sanford35_5.9's Avatar
sanford35_5.9
Find your chime box under the dash and see if it will come apart. If so then take the speaker out of the box and everything will still work like normally but it wont make anymore noise. Just make sure your shut your lights off and keep checking your gauges, cause if anything happens then you wont hear it trying to let you know.
Old Sep 24, 2009 | 10:23 AM
SMKNRAM's Avatar
SMKNRAM
I had the same issue with the left rear brake light. but I was getting moisture inside the taillight assembly. Fixed the leak and used some anti-corrosive goop and it seams to be doing better.
Old Sep 24, 2009 | 11:01 AM
big_kahuna's Avatar
big_kahuna
Good to know, I'll check for moisture and make sure it's sealed up tight. Hopefully it will fix it for good!
Old Sep 24, 2009 | 12:39 PM
gmb4fords's Avatar
gmb4fords
back when i first got my truck i had a bulb go out. and it was the left brake light as well lol.... and i def got the chime thing going on. but it only took me a minute to pull over at the parts store.... man that ish is annoying!
Old Oct 30, 2010 | 01:29 PM
melisssa's Avatar
melisssa
where is the chime located ,so that ican disingage it !
I have a 2003 ram 1500
Old Nov 26, 2010 | 06:12 PM
JayEtter's Avatar
JayEtter
Default lamp out light
i have changed all lights it only chimes when i turn on my right turn signal no lights are out but the flash funny i just changed them
Old Oct 19, 2012 | 09:14 AM
joeylead's Avatar
joeylead
any infor on this? i am getting the chime and lamp out light. i have replaced all the bulbs and both rear taillight boards and its not fixed. i need to disable the chime
