Cab lights not working
Old Sep 9, 2009 | 07:32 PM
SEV7716's Avatar
SEV7716
Default Cab lights not working
I just installed my cab lights that I bought from Recon, I didnt want to drill a big hole into my roof so I cut the connectors off of the cab lights and then spliced the connectors back to the lights. Also in the kit I got the ground wire was a short wire with a loop at the end. I spliced the main wire from the harness into the factory cab light harness like the directions said to, I attached the ground wire loop to a screw in the roof of my truck, when I went to turn the lights on i got nothing. I tried messing with the groun wire, moving it around and all that, finally I just cut the loop off and spliced some extra wire to the ground and spliced that into the factory ground connection in the cab light harness, still nothing. I mad sure all my splices were good. So now all I got are 5 "decorative" lights. I will admit Im not the most electrical savvy guy. Anyone got any advice?
Old Sep 9, 2009 | 09:54 PM
HammerZ71's Avatar
HammerZ71
Take a meter and trace it out, where is the last place you have good power?
I had no issues on my install, but I drilled the roof and went straight by the book...
Old Sep 9, 2009 | 10:06 PM
dodge it then ram it's Avatar
Bad fuse maybe?
Old Sep 10, 2009 | 08:26 PM
DodgeThunder's Avatar
DodgeThunder
How did you run the wires into the cab if you didnt drill the big holes? Like hammer said Id check the power wire at the harness in the passenger side apillar and see if theres power and go from there.. you might have the wires crossed.. although It might not matter depending if your LEDs are polarized..
Old Sep 11, 2009 | 02:26 PM
SEV7716's Avatar
SEV7716
I cut the the cab light connectors off the light and put the wires through the drill holes, I then reconnected the connectors to the lights by splicing the wires back together. And then I connected The cables to the the pillar like the instructions said. I replaced the fuse and still nothing, all I can maybe think of is either the grund is messed up or like Hammer said there might not be any power. I will have to check that.
Old Sep 11, 2009 | 02:45 PM
RubberFrog's Avatar
RubberFrog
The leds are directional. If you hooked the hot lead of the light to the ground of the harness, they wont work. Try reversing the hot and ground and I'll bet they come on.
Old Sep 11, 2009 | 04:08 PM
SEV7716's Avatar
SEV7716
with the harness, is there a certain way that the connectors from the lights have to go into the connectors on the harness? Like I stated in my first post, Im not the most electronically savvy guy, I usually just jerry rig stuff up and mess with it till it works but this I cant figure out.
Old Sep 11, 2009 | 04:32 PM
RubberFrog's Avatar
RubberFrog
Just make sure all the red leads go to one wire, and the black leads to the other. Then you can simply swap the leads at the the ground/power source to get it working.
Old Sep 11, 2009 | 06:25 PM
SEV7716's Avatar
SEV7716
Oh yeah I had all the correct wires connected right. As in my case with these cab lights, the problem turned out to be stupid simple. The fuse kept blowing. It was a 15 fuse. I replaced it with a 20 fuse and all the lights came on. By the way Rubberfrog where did you get the custom badges for your truck?
