camshaft
Old Nov 29, 2009 | 03:00 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by blackbetty696
im lookin at getting one of the jegs kits at http://www.jegs.com/p/Mopar-Performa...46961/10002/-1 witch one should i get?
What are your plans for tuning and what are looking to get out of your cam? The link you posted is not what you should be looking at. Give us some info about what your plans are and we can point you to the right cam.
Old Nov 29, 2009 | 07:57 PM
blackbetty696's Avatar
blackbetty696
i dont know were to look for a tuning kit, but i want a nasty bad *** idle and better performance so i was lookin at rocker arms and cams and didnt know wat ratio i can do
Old Nov 29, 2009 | 08:14 PM
Off_Road_Teacher
Well you are in the same boat for tuning as I am since we both have 04 5.7's. If you want to run a big cam you are going to need a custom tune of some sort. You can get a custom tune with a DSP or a SCT tuner. Problem with them is that they don't have any trans control for our trucks. You could do a SC with a PSC1 piggyback or an SC/SCT stack. Then you would have the trans control of the SC with the engine tuning of the PSC1 or the SCT.
Old Nov 30, 2009 | 04:34 AM
RamIt33's Avatar
RamIt33
If you are looking for some performance parts for your hemi check this site out. I was looking at the cams here on this link, the hemi street cam is the way i am going to go.
http://www.fasthemis.com/index.asp?P...S&Category=566
Old Nov 30, 2009 | 06:56 AM
Off_Road_Teacher
What made you decide to go with the hemi street cam? There are no specs on there describing the grind. It doesn't mention any need for changing out the springs or rods which must mean it is a pretty mild cam.
Old Nov 30, 2009 | 08:50 AM
truckin151's Avatar
truckin151
Specs:
Full Description
It will increase airflow and engine output at 3,000 rpm and above
while maintaining low rpm drivability characteristics. Requires Non-MDS hydraulic lifters. Recommended Springs: 5.7L Hemi Production Springs.
Specifications:
• Duration @ .006": 259º Intake/267º Exhaust
• Duration @ .050": 204º Intake/210.5º Exhaust
• Lobe Separation: 116º
• Intake Centerline: 120º ATDC
• Lift: .500" Intake/.488" Exhaust
• Basic rpm: 3,000 - 6,200
http://www.moparsupercenter.com/5-7l...tp5153325.html
Old Nov 30, 2009 | 09:26 AM
Off_Road_Teacher
Originally Posted by truckin151
Specifications:
Now I can see why it doesn't say anything about the spring swap. That is a very mild cam and quite expensive at over $600.
Last edited by Off_Road_Teacher; Nov 30, 2009 at 09:36 PM. Reason: Bc my Iphone makes me look like I don't know how to spell.
Old Nov 30, 2009 | 09:04 PM
blackbetty696
what size does that start at were you have to swap out springs and stuff?
Old Nov 30, 2009 | 09:35 PM
Off_Road_Teacher
Honestly, I would be leary of putting in any cam and not replacing the springs. These stockers are pretty weak and the last thing you need is to break a spring and have catastrophic failure because of it. For $60 you can get a set of 6.1 exhaust springs and not have to worry about breakage. But to answer your question, it is usually when the lift goes over .500 that new springs are required.
Old Nov 30, 2009 | 10:14 PM
blackbetty696
what would be a good cobination of cam and roller rocker arm ratios and springs and rods for what i am trying to do?
