Remove stock fan
Old Sep 18, 2009 | 07:42 AM
  #31
kregier's Avatar
kregier
I'm quite surprised it's causing this much difficulty. I've always used a big wrench (24"+ handle) and hammer to get fans off. And yes, it will still turn so you have to re-adjust 4 or 5 times, but it's the impact that's slowly breaking the nut loose. I've never had to hit it more than 10 times, and that was working with a buddy on a junk yard motor. What are you getting nicks and dings on?
Old Sep 18, 2009 | 09:31 AM
  #32
tk04hemi's Avatar
tk04hemi
well the nut is a completely different color after ive beat the hell out of it so far. ive nicked a couple of the edges of some pullies. my buddies coming over today so ill let yall know what happens then..
Old Sep 18, 2009 | 09:38 AM
  #33
nim81's Avatar
nim81
ive used a strap wrench around the pulley and also used vicegrips to to hold the pulley still, never really had much of a problem, dont know how different the 5.9 is compared to your motor though
Old Sep 18, 2009 | 10:38 AM
  #34
motorhead426's Avatar
motorhead426
Just to clarify... your turning the wrench to the passenger side correct? When I did mine, I put the wrench on the nut, and gave it end of the wrench a swift tap with a dead-blow hammer. The guy that mentioned using bolts in the holes of the pulley is not a bad idea, but doing it that way should only take a little force. Just don't damage your water pump. After reading 4 pages of this thread, something seems wrong. I've never heard of the nut being that tight. The other thing you could try is using a strap wrench to hold the pulley while someone taps the wrench. This is a mod. that is well worth your time and money! Good luck!
Old Sep 18, 2009 | 06:50 PM
  #35
chambers's Avatar
chambers
Is the pulley staying still and just the bolt not turning? If that's the case then maybe put a piece of pipe on the end of the wrench to give you some more leverage to pop that damn thing loose.
Old Sep 18, 2009 | 07:24 PM
  #36
MikeHTally's Avatar
MikeHTally
After all this, you could have ordered a spanner, gotten it and been done.
Old Sep 18, 2009 | 09:46 PM
  #37
Mega-Hemi's Avatar
Mega-Hemi
4 days? I would have sawzalled it by now.
Old Sep 20, 2009 | 01:17 PM
  #38
tk04hemi's Avatar
tk04hemi
I am going to just cut off the stock clutch fan after the bolt....the bolt will still be there if it ever feels like coming out but I just want to put this e fan in already. And yes it is a regular thread so I was hitting the wrench to the passenger side or left. Now wheres that sawzall...
Old Sep 20, 2009 | 01:24 PM
  #39
chambers's Avatar
chambers
Alright, get that thing off there and keep us updated on the e-fan install.
Old Sep 20, 2009 | 03:36 PM
  #40
chefred112's Avatar
chefred112
which way you hittin it..I just took mine off a few minutes ago and it wasn't that hard or stuck on...I do have a home made spanner wrench that fit into the holes of the water pump pulley...lookin at it from front of motor, i'm turning it counter clockwise, like a normal nut/bolt comin off..
