Got my fox box
sorry no pics you guy know what they look like. i got the dual 10" ported set up for 100.00 locally. i have some doated alpine type-r waiting on me in colorado, i just have to make it up there to get them. now the question the seat is angled a lot more than i thought they would be are there spacers or something? could i just make some maybe an inch. i just want to be safe in whatever i do because i have my kids with me alot of the times. thanks.
thats cool thats a super deal on it im not sure bout the mounts tho...but i cut my carpet in the bottom of the holes to fit my box in better and so my seat wasnt leaned i only made releif cuts with razorblade to help....maybe this will work...
You should just remove the carpet. it's only held on with those little plastic tabs along the front. You could always just glue speaker box carpet to the painted surface that shows to clean it up if you wanted. That's what i did with my box.
in all honesty i might just remove the carpet eventually cause im thinking i wanna build a fiberglass enclosure so i can fit better subs with larger magnets so i can acheive better mounting depth for a better system... i just gotta get to it...and expaeriment with f/g i also would stretch it back under the rear seats more than my current mdf box for more airspace and if i do this it will be in there prolly permanently cause i would f/g it in the truck or make some sort of template any ideas for me......
His boxes do come with spacers. As for bolting it down. I went to Lowes and got some 1/4*20*2" bolts, flat rubber backed and spring washers and nylon lock nuts. I took my subs out (I have the dual 12" box) and got my drill with a 1/4" bit and drilled in the bottom of the box through the floor pan. I put the rubber backed washer on the bolt first and run it through the box and floor. Then under the truck I used the spring washer and nylon lock washer.
I did this on both sides on mine and have had no issues. I called Joe and talked to him about this some time back because his boxes used to come pre-drilled and with self-tapping screws to bolt it down but he said people complained about it having a pre-drilled hole in the bottom (potential air leak) so he quit doing it.
Trending Topics
yeah i talked to him he said 15.00 for the spacers and bolts. i figured it wasn't a bad price. my main concern being the seats i want them secure solid for my chillens.
