tire size
Old Apr 1, 2005 | 01:41 AM
goose2's Avatar
goose2
Default tire size
What is the biggest tire you can put on a 2004 2500 4 by 4 with out lifting it? I have a set of 18" tires laying around I would like to use.
Old Apr 1, 2005 | 01:44 AM
ross944's Avatar
ross944
Default RE: tire size
33"....after that it rubs on turns
Old Apr 1, 2005 | 01:53 AM
goose2's Avatar
goose2
do you no anybody that has run this big of a tire on these trucks?
Old Apr 1, 2005 | 01:15 PM
DonG's Avatar
DonG
Many Rams come with 33 in tires from the factory. I think you are confusing rim size with overall wheel/tire size. You can put 33s on nearly any wheel size available.
Old Apr 4, 2005 | 04:47 AM
EatnFordsShtnChevys's Avatar
EatnFordsShtnChevys
believe it or not but i have 35's on stock rims without a lift on my 03' 1500.
Old Apr 4, 2005 | 05:04 AM
ross944's Avatar
ross944
35"s.....no lift......pics please......[sm=jawdrop.gif]
Old Apr 4, 2005 | 05:09 AM
ross944's Avatar
ross944
sorry...wrong face[sm=bs.gif]
Old Apr 6, 2005 | 10:43 PM
salomonskier's Avatar
salomonskier
Does it make a difference on which packages you have when it comes to maximum tire size?
Old Apr 8, 2005 | 10:20 PM
05HD's Avatar
05HD
A larger wheel diameter does not mean that the tire is larger... you need to go by the OD of the tire and the tread width. On a stock offset wheel, 35x12.50 RXX will fit an un-lifted 2500 with minimal rubbing. 2.5" lift coils will make the situation better.
Old Apr 11, 2005 | 12:55 PM
NDW13's Avatar
NDW13
I've got 265/70R17's on my ram, which originally had 245/70R17's and it filled up the wells nicely.
