Trans Pan Stripped thread
Old Sep 27, 2009 | 07:31 PM
PX's Avatar
PX
Default Trans Pan Stripped thread
Hi guys! I have an 04 1500 4x4 with the 4.7 motor. I noticed some trans fluid under my truck yesterday and climbed underneath to have a look. some of my bolts were a little loose (last serviced by the dealership about a year ago). So I tightened them up and found that one of the bolts has some stripped threads. What can I do to fix this? I've heard of helicoils, but I'm not familiar with them. can anyone provide any advice or how to fix this? Thanks in advance!
Old Sep 27, 2009 | 08:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The only thing I can think of is the heli coils or re-threading the hole with a slightly larger tap.
Old Sep 27, 2009 | 08:39 PM
big guy's Avatar
big guy
Helicoil is the way to go. Google it. I'm sure you will find find some good info maybe a you tube clip.
Good Luck.
Old Sep 27, 2009 | 08:54 PM
05RamMan's Avatar
05RamMan
HeliCoils or re-tap and use a slighty larger bolt. Either way it is pretty easy, And either way requires you to drill a slightly larger hole. HeliCoils can be had at any autoparts store.
