Anyone got pics of OEM skidplates?
Old Sep 28, 2009 | 07:22 PM
Drangiz's Avatar
Drangiz
I have been looking into getting skidplates for my truck. This thread popped up, and seems like a good place to ask. What are the best options for putting skidplates on my truck? Are there good aftermarket ones? Should I just get OEM ones? Also, if OEM are the way to go, could someone hook me up with part numbers?
Old Sep 28, 2009 | 07:41 PM
SMKNRAM's Avatar
SMKNRAM
the funny thing is that t skid in the back is plastic!! I was totally surprised when I took it down!!
Old Sep 28, 2009 | 07:51 PM
98cherryram's Avatar
98cherryram
The front one is offset if that makes any difference... yeah, I think all of the oem skidplates are plastic, they arent meant for heavy impact, just for sliding on stuff, hence the name skidplate, not impactplate.
Old Sep 28, 2009 | 09:00 PM
lxman1's Avatar
lxman1
Site Moderator
Doesn't the factory use large, self tapping bolts? This is why the holes aren't tapped.
Old Sep 28, 2009 | 09:26 PM
kicker417's Avatar
kicker417
in my truck they are the same ones for transfercase and diifs
Old Sep 28, 2009 | 09:52 PM
dirtydog's Avatar
dirtydog
Moderate User
This one here is OEM and is fairly thick steel.
Lxman, the bolts he gave me are originals. They appear to have a slight taper and are triangular in shape at the tip. I just don't see them being able to tap through metal that is 1/4" thick. Just doesn't seem practical? The bolts themselves are fairly thin, not thick at all.
Old Sep 29, 2009 | 12:11 AM
HammerZ71's Avatar
HammerZ71
yep, is front diff to be sure and yes they are quite heavy steel. I remember when I put mine up for sale the first guy interested was from Texas, shipping killed it. Ended up selling them to a guy about 45 miles away, came and got them...
Old Sep 29, 2009 | 01:01 AM
98cherryram
I cant believe they expect you to drill into the frame... That compromises the frame... Thats the reason I never drilled into the front crossbar behind the grill to put lights in there...
Old Sep 29, 2009 | 04:24 AM
Lowlygovemployee's Avatar
Lowlygovemployee
On my 2008 1500, the front and rear skid plates are the same. They are steel, not plastic. To put that skid on the rear, you will need the rear cross member also.
Old Sep 29, 2009 | 06:39 AM
dirtydog's Avatar
dirtydog
Moderate User
98 Cherry, the holes are there, just that th threads aren't tapped. Drilling a couple of small holes smaller than pen thickness isn't going to cause any issue's in frame strength. Now drilling multiple holes next to each other will, but the frame is so thick, I wouldn't think twise about drilling into it. My Silverado frame was a C-channel and not box, so there's a big diff right there.
