Rear end ratio upgrade
I own a 2007 Mega Cab 1500 Hemi with the 3.73 rear end. I have thought about upgrading to a 4.10 rear end to tow more. Is there anyone out there that has done the same.
Thanks
Thanks
yup you wont be disapointed in the 4:10 at all
i had a 2004 ram 1500 single cab with 3:73's upgraded to 4:56's liked it
now in my megacab it was speacial ordered with 4:10's reallllly love them allot more than the 4:56's . now thats 2 different trucks and weights but having ssaid that for $hits and grins i drove a megacab with 3:73's and it was a dogg compaired to my mega with the 4:10's
Well I'd say if your in the diffs then go for 4.56's its only about another
200~ or so rpm increase on the highway from 4.10's but if you plan on
towing or adding bigger tires then the big gears are the way to go.
After researching the difference in the towing capacity I am not sure if is worthe the money going to the 4.10. Can the Mega Cab 1500 Hemi 4x4 pull 10k Ibs? I know Chrysler has the truck rated at a weak 7,300 Ibs.
Gears don't add any power, they simply give you a mathematical advantage and take a LOT of work off the transmission and put it on the engine, which is much better designed to handle it.
If ordering from the factory on a new truck, I'd opt for the 4.10s in a heartbeat. If purchasing aftermarket, I'd step right on up to 4.56s on a vehicle that was going to see larger tires and/or towing use.
200 more RPMs at speed will make such a small mpg difference you probably would barely be able to measure it, but that little bit of extra rpm will significantly help you get a load moving without as much pressure on the throttle.
IMO, if you're going to go to the expense of a gear swap, go straight to the 4.56s...
I have read in a Dodge truck towing guide, published in about 2005 that going from 3.92 gears in a 1500 to 4.56 effectively increases towing capacity by 1000 lbs. Also I read a link on another forum that pointed to some camper association page that basically stated the same thing. I'll try to find the site, but it was a few years ago that I read it.
