ignition controlled power supply
Old Oct 1, 2009 | 02:36 PM
WWJD's Avatar
WWJD
Default ignition controlled power supply
I have been trying to hook up my electric fan for a few days now. And only seem to find problems as I go along. This is the first time I have done anything under the hood.
What wire can I use? I tried a pink yellow wire that is supposed to be the cigar lighter. Right now it is hooked up to the waser fluid senor but I still can't get any electricity to my switch.
Both wires I have tried are a really small gauge wire and I am using something like a 14-16 gauge on them. Could this be a problem.
Everything is firing but this is the only thing I have had trouble with unless my relay is bad but it is brand new.
Old Oct 1, 2009 | 04:15 PM
WWJD's Avatar
WWJD
I am about to just put my clutch fan back on and trash everything I have been working on.
The net comes up with nothing. I asked a guy at best buy but he told me a wire that is under the dash. The blue ignition wire. I am going to break down and quit trying to learn how to work on my own vehicles.
bump
Old Oct 1, 2009 | 08:17 PM
WWJD's Avatar
WWJD
Is this some sort of secret?
Old Oct 1, 2009 | 08:19 PM
MikeHTally's Avatar
MikeHTally
A fan controller will answer all your needs. You need it to switch the fan on as needed anyway.
Old Oct 1, 2009 | 08:25 PM
nim81's Avatar
nim81
this is an ignition controlled power source on my truck.
Old Oct 1, 2009 | 08:27 PM
WWJD's Avatar
WWJD
dood, I have everything I need and then some.
It's almost like it is forbidden to tell any one how to find and use a ignition 12v power source on the internet.
Old Oct 1, 2009 | 08:29 PM
WWJD's Avatar
WWJD
NIM!!!! Thank you, you are flippin awesome dood.
Can I just ask you how you did it? I mean it looks simple but I just want to be sure cause I an this close to putting my clutch fan back on....
Old Oct 1, 2009 | 08:30 PM
MikeHTally's Avatar
MikeHTally
Originally Posted by WWJD
dood, I have everything I need and then some...
Except a fan controller and some instructions, apparently. Under the steering wheel and behind the knee bolster should be a four-wire harness. One of those wires is a lime green/black wire. It is a switched hot.
Old Oct 1, 2009 | 08:35 PM
nim81's Avatar
nim81
used a male spade connector , fits right into there.
like the one on the left...
**thanks to some random photobucket account for this image*****
Old Oct 1, 2009 | 08:38 PM
WWJD's Avatar
WWJD
I have a hayden controller, intalled, and under the hood
