Axle leaf questions
no new shocks with the 1" blocks
I think mine are normal also. Ive been looking through a lot of older threads for other things and there have been a lot of pics I have seen (unrelated to this topic) but they all are also about the same. So I guess I am normal. However, I think I will add an "add-a-leaf" later on and pull my 1" blocks out and likely have to let my lift shackles down a notch or so to be back level.
I think thats the best way to do it.
Hey Weedahoe, I added the Air Lift Ride control air bags back in April and love them. I got them off Amazon.com for around 210+. You won't need to do the shackle switch and you can adjust your ride height and you can add anothe 1500 lbs in weight in the bed no problem. Check them out before you do the block switch. BTW the ride is great with about 5-10 lbs of air in them while the beds empty, no bouncing around anymore.
