Limited slip?
Old Oct 3, 2009 | 05:31 PM
jdpartsman's Avatar
jdpartsman
Default Limited slip?
Hello. I'm new to this forum. I have an 05 1500 crew cab SLT 4x4 HEMI. When I mass the gas it only spins the right rear tire.....alot. I had the local dealer pull up the build codes. It had a 9.25 LD axle with 3.92 gears. I assume the LD means I have an open rear diff? Would LS mean it has a limited slip?
Anyway.....she's a one-wheel-wonder. On wet pavement it's really bad. What would be the cheapest/cost effective way to get two wheel action? I do very little off-roading so I don't need/want a locker. Thanks!
Old Oct 3, 2009 | 06:10 PM
Yachtsman1304's Avatar
Yachtsman1304
the LD actually means "light duty" on that part. This is what my build sheet says for limited slip.
DSA Anti-Spin Differential Rear Axle
Old Oct 3, 2009 | 06:39 PM
jdpartsman's Avatar
jdpartsman
Yeah...mine don't say that. Too bad, it's really the only thing I dislike about it right now.
Old Oct 3, 2009 | 06:42 PM
blackbetty696's Avatar
blackbetty696
the cheapest but not the best way is to weld it but that will jack with your turns, moes performance.com has stuff but youll pay a good buck to get it
Old Oct 4, 2009 | 12:44 AM
lxman1's Avatar
lxman1
Site Moderator
The cheapest route would be to find a wrecked truck with the factory LSD in it, but an aftermarket unit is a better choice.
Old Oct 4, 2009 | 02:15 PM
jdpartsman's Avatar
jdpartsman
Can I get one from Dodge, or is the aftermarket going to be cheaper?
Anyone here gone down this road before? Thanks.
Old Oct 4, 2009 | 02:29 PM
draco8494's Avatar
draco8494
dunno about prices but the stock dodge LSD's tend to grenade, even jeeps do it, anyways an aftermarket LSD is gonna be the way to go, last longer and a better unit IMO
Old Oct 4, 2009 | 06:20 PM
dodgenitto's Avatar
dodgenitto
I went with the Detroit Tru Trac and have no regrets. I had the Stock LSD and it still wouldn't engage sometimes unless I tapped the brakes while hitting the gas. So I recommend an aftermarket one for sure.
