What is this? And Where does it go???
Old Oct 5, 2009 | 12:49 AM
truckin151's Avatar
truckin151
Question What is this? And Where does it go???
While I was installing my sway bar I found this hose just sitting under the back of the truck and I do not know where it goes. It is tied in with the brake lines... Any Ideas?
Old Oct 5, 2009 | 12:59 AM
jarhead03's Avatar
jarhead03
its a hose that serves no purpose. lol Id say its someones engineering skills or lack of is mor like it. Is it rubber or plastic?
Old Oct 5, 2009 | 01:04 AM
truckin151's Avatar
truckin151
Its a rubber hose
Old Oct 5, 2009 | 01:07 AM
tuned93's Avatar
tuned93
its a vent hose for the brake lines... i know cuz when i swapped rear ends i asked myself the same question. (mine was plugged too) i just zip tied it up and out of the way.
Old Oct 5, 2009 | 01:11 AM
truckin151's Avatar
truckin151
so it serves no purpose except as a vent line? Well thats good to know, I was messing around trying to get a plate installed and moved a few things around and the hose dropped on my face... I thought I disconnected something important for a while but it was plugged... it was one of those "what the hell is this?" moments.
Old Oct 5, 2009 | 01:19 AM
tuned93's Avatar
tuned93
haha, yeah... the perverbial "awe crap" moments. i had one of those the other day when i was changing my tranny filters. i was slowly prying the trans pan off when it busted loose and i got 6 quarts of trans fluid all over myself and my garage floor. at that point i figured, F*ck it... im already covered in it, i might as well finish now.
Old Oct 5, 2009 | 01:48 AM
hemiguy0302's Avatar
hemiguy0302
Actually its the breather for the rear axle. Looks exactly the same as the breather on the front of my 2500's axle. Zip tie it high so it satys dry and water doesnt find itsd way into the dif. housing.
Old Oct 5, 2009 | 01:52 AM
Shiloh 24's Avatar
Shiloh 24
So is this Dodge's answer to keeping water out of the rear diff? I remember seeing a thread about that, does this just simply relocate the vent hole higher so water has a harder time getting in?
Old Oct 5, 2009 | 02:10 AM
hemiguy0302
yep thats the reason.
Old Oct 5, 2009 | 09:50 AM
truckin151's Avatar
truckin151
Wel the only thing I would question about it being for the rear diff is that it is tied into the brake lines and I am positive of that. The main brake line ties into the fitting then branches off going to the drives side and passengers side brake lines and then this hose comes straight up from the top of that fitting.
