water spewing from tail exaust
Old Oct 6, 2009 | 07:15 PM
thataway5000's Avatar
thataway5000
Default water spewing from tail exaust
i bought the truck last November, a month later we had a freeze one night, and turns out the dealership, went cheap and used water instead of antifreeze. anyways i put antifreeze in and everything was fine for a few months, but summertime came around and i started overheating. then the final draw came when i tried to add water, but the water was flowing out of the tailpipe, and i do mean flowing, just as fast as i can pour it in. i need help? anyone know what could be wring with my truck?
Old Oct 6, 2009 | 07:24 PM
jdfisher's Avatar
jdfisher
what engine? sounds like a head gasket or a cracked head, also use of water or wrong coolant can speed up corrosion of radiator and cooling components of engine including head gaskets.
Old Oct 6, 2009 | 07:25 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Does your truck still run? And when you say flowing, do you really mean it was pouring out as fast as you put it in??????
Old Oct 6, 2009 | 08:13 PM
thataway5000
yes pouring out as fast as i pour it in. motor size is 4.7. no the truck start at the moment. ive pulled the oil pan, and couldnt find and metal pieces in it. i plan on fixing it myself, but need to know where to start. im thinking blown head, because of how fast the water is spewing out the tail pipe. i just got done replacing the head on a neon so i think im capable of doing it on the ram. i know its gonna be alot harder, but im up for it.
Old Oct 6, 2009 | 08:14 PM
Off_Road_Teacher
Head gaskets on the 4.7 are known for blowing out.
Old Oct 6, 2009 | 08:24 PM
thataway5000
but would just a head gasket cause it to spew out like that?
Old Oct 6, 2009 | 08:37 PM
Dubsport's Avatar
Dubsport
Yes... under the right circumstances it will flow out that fast!
Old Oct 6, 2009 | 08:40 PM
thataway5000
what are the chances in the head being warped?
Old Oct 6, 2009 | 09:38 PM
PETE_YK's Avatar
PETE_YK
So is this dealer like, retarted??? 100 percent water not only speeds up corrosion by a thousand times, your water pump wouldnt last very long! Sickens me to even think that there is a half-assed dealer out there that would put just water into a cooling system.
Sounds like you got shafted
Old Oct 6, 2009 | 10:15 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, if the leak or crack is bad enough then the piston(s) would act like a pump and suck water in the chamber and pump it out past the valves.
