New Intake Manifold
Old Oct 7, 2009 | 12:48 AM
HemiLonestar's Avatar
HemiLonestar
Originally Posted by Shiloh 24
Don't get me wrong the 5.9 doesn't skimp on power but I could get better mileage and almost a hundred more hp stock with a hemi! Yes, there are parts for the 5.9 but look at stuff like tuners. Their all designed to work with the hemi, and this manifold is designed only for the hemi.
You do know the stock carb'd 360 crate engine is 360-380hp, right?
Old Oct 7, 2009 | 12:56 AM
OlDirtyJohn's Avatar
OlDirtyJohn
someone posted that same manifold up a couple months ago. there was a lot of good info about it that came up in that thread. if my memory serves me correctly, someone was saying that it didnt show very good numbers at all on the dyno.
Shiloh 24's Avatar
Shiloh 24
So if mine was carbed I could have 360 hp? That doesn't make any sense. I am a power hungry teen that doesn't want to spend 5k on a supercharger.
Old Oct 7, 2009 | 01:27 AM
truckin151's Avatar
truckin151
That intake is made for more of the higher RPM range, where our trucks will not benefit from it at all. There was a post on another site where the guy testing it lost hp with it vs running through the stock manifold.
http://hemi truck club.infopop.cc/eve/forums/a/tpc/f/3260069252/m/629105522 (take out the spaces)
That being said the one to check out is the mopar Drag Pack Hemi Intake
http://www.lxforums.com/board/showthread.php?t=140442
http://www.moparsupercenter.com/chal...dp5155288.html
Should work on our trucks too but I have yet to see anyone install one. Still pricey though
Old Oct 7, 2009 | 06:36 AM
dirtydog's Avatar
dirtydog
Moderate User
I don't see any numbers on thier site which tells me something is up. i know most of the intakes that were created for my mustang only benefittted the car in the high rpm range and lost out down on the low end because of the length of the runners. I'm willing to bet that this is pretty much the same. Loss in hp down low and the only way to gain up top is to have a high lift cam. i bet with a stock engine, the output is terrible!
Old Oct 7, 2009 | 08:56 AM
motorhead426's Avatar
motorhead426
Dude you just made me hate my 5.9! First off I get worse mileage than a Hemi, second I have less power, last but not least you guys get all the freakin upgrade parts and performance stuff!
No, thats the Ford and GM guys... they get all the performance stuff. I think mostly due to the aftermarket having problems 'cracking' the DCX codes...
Old Oct 7, 2009 | 09:02 AM
2006NightRunner's Avatar
2006NightRunner
It looks like a Carb manifold that has a Throttle body adapter.
Old Oct 7, 2009 | 11:32 AM
HemiLonestar
I must've missed it, I would've remembered seeing that one before.
Old Oct 7, 2009 | 11:48 AM
dunerider650's Avatar
dunerider650
yep it does....
Old Oct 8, 2009 | 01:06 PM
HemiLonestar
That's because it IS. They just went and engineered it to be a bolt in with room for modification later. If it's a high RPM manifold, then it's useless for a QC.
