Port Throttle Body
Old Oct 8, 2009 | 11:53 PM
sharkhunter10's Avatar
sharkhunter10
Default Port Throttle Body
Ok, Ive searched and found many different answers and wana be sure I do this right be for I mess something up. Im going to have time to port my throttle body this weekend and want to do it. I want to do it my self to save cash and time. Me and a buddy did his on his 2004 chevy 1500 a while back. it made a huge throttle responce difference, but I dont remember quit what we did. Can any one give me instructions on how to do or were to find some!
Thanks
Old Oct 9, 2009 | 07:52 AM
sharkhunter10
anyone?
Old Oct 9, 2009 | 08:14 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I know to port heads there are several tool you can use but the heads I used to do were Olds heads and cast iron so it took longer and less metal came off. The TB is a different and softer metal but I would imagine using a dremel tool and a sanding drum would be a way to do it. Go slow and have a micrometer so you know how much you are taking.
Im sure others will chime in with more and maybe better info.
Old Oct 9, 2009 | 08:31 AM
dirtydog's Avatar
dirtydog
Moderate User
Gonna take a long time with a dremel, so be patient. Don';t grind one are at a time. Keep the dremel bit moving. the dremel bit i used to "fake port" my mustang T/B was made for aluminum bet yet would get clogged all the time. it was a PIA. i say fake because it really isn't a port unless the center bore where the butterfly plate is enlarged. You can have a 1,000mm T/B front and back, but if that butterfly opening is still 80mm, it's only as goo as an 80mm T/B. The ONLY benefit is contouring right near the plate so when it opens the slightest amount, the opening for air to squeeze through is larger than stock which results in a touchier T/B for "response". That is the only benefit you will get. There will be no HP increase FYI
Old Oct 9, 2009 | 08:34 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
If you end up doing it take some pics of the process. It would be helpful to other guys who want to do the same mod.
Old Oct 9, 2009 | 08:37 AM
dirtydog's Avatar
dirtydog
Moderate User
Teach, i thought you have a Fastman T/B that is machined?
I was debating whether or not to do some shaving around the butterfly myself, but i just don't know if i wanna deal with a super touchy throttle. it was kinda onnoying on my mustang for normal driving.
Old Oct 9, 2009 | 08:47 AM
Off_Road_Teacher
I do have the TB from fastman but I was thinking that other guys who don't want to go that route might want to try it themselves. It would be a pretty good diy if it works well.
If you don't like a touchy throttle you probably don't want to port out your tb. That is one of the biggest changes I notices when I changed to my fastman tb. Personally, I like a touchy throttle but it is just a matter of personal preference. Around town driving is a little better too with the tb.
Old Oct 9, 2009 | 08:49 AM
dirtydog's Avatar
dirtydog
Moderate User
I imiagine once the trans controls that SC is working on, that there won't be much of an issue or need for a ported T/B.....hopefully...lol
Old Oct 9, 2009 | 01:15 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I understand what you are saying Dogg about porting around the butterfly area but if you do that wont that let more air pass the plate when closed and how would that affect idle?
Old Oct 9, 2009 | 01:34 PM
dirtydog's Avatar
dirtydog
Moderate User
It would effect idle if you kept the same size plate. You would need to install a larger plate to keep the hole closed. The only real way to gain CFM flow is to make the plate bigger.
