Please help! This noise is making me crazy!!!!!!
Old Oct 9, 2009 | 07:00 AM
JOHNSN10's Avatar
JOHNSN10
Default Please help! This noise is making me crazy!!!!!!
2005 ram 1500 quad 4.7 v8 29k miles
ok so this is alittle hard to explain but when im driving normal down the road my truck makes a chirping sound. Sometimes when goin over small bumps and sometimes when the road is slightly not smooth. It usually doesnt do it all the time constantly but it does it everytime while driving. This sound isnt loud and it sounds like something is rubbing something else to produce this chirping type sound. It sounds like its coming from the drivers side front and near the steering wheel area. Its mostly when on a non smooth road. But its weird b/c it doesnt always do it when driving over bumps and stuff. Anybody have any clue what it may be? This noise drives me crazy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
Old Oct 9, 2009 | 07:38 AM
dirtydog's Avatar
dirtydog
Moderate User
sounds like a dry bushing rubbing against metal. get some silicone spray and go crazy? Duno what else to tell ya.
Old Oct 9, 2009 | 09:13 AM
abarmby's Avatar
abarmby
Sliders between the leaf springs????
Al.
Old Oct 9, 2009 | 11:31 AM
tuned93's Avatar
tuned93
mine does the same thing! aaahhh its rediculous! i took a can of PB blaster and shot the whole front end and it still does it... still havent figured it out!
Old Oct 9, 2009 | 11:39 AM
muddauber5.7's Avatar
muddauber5.7
Did you spray your sway bar bushings with silicone.
Old Oct 9, 2009 | 11:43 AM
tuned93's Avatar
tuned93
not with silicone... just PB blaster
Old Oct 9, 2009 | 11:52 AM
BadHab1t's Avatar
BadHab1t
get some silicone and spray em all and if that dont work look into getting new control arm bushings but use energysuspension.com bushings they are the best and will last forever.....
Old Oct 9, 2009 | 03:39 PM
Snaximus's Avatar
Snaximus
Are you positive it's in the suspension?? I had a slight chirp kinda sound that turned out to be the A/C line rubbing on the inside of the engine compartment. I took a piece of foam copper pipe insulation and wedged it in there. Stopped my chirp. ( tried to put a pic in here but couldn't.) Anyway, if the engine compartment is anything like the '02's there's an A/C line that is real close to the sidewall by the air filter box. It elbows down. It was rubbing there. Worth a shot.
Old Oct 9, 2009 | 03:50 PM
ramhunter9's Avatar
ramhunter9
could be your dash . buddies did this
Old Oct 9, 2009 | 03:55 PM
doneking's Avatar
doneking
Next time it's making the noise...try this. Pull over and pop the hood. Find the two little black rubber ***** that are on the cross beam that runs along and in front of the radiator. Those two bumpers that cushion the hood were sqeaking on mine and it drove me crazy.
Wipe/clean them off, spray them with some silicone or something and adjust them up or down about a 1/4 of a turn. See if that helps the noise. It solved mine, but occaisionally I have to adjust them when they start up again.
Hope that helps.
DK
