Adding to coolant
Old Oct 9, 2009 | 06:48 PM
Snaximus's Avatar
Snaximus
Default Adding to coolant
Just went through a whole bunch of back and forth with the dealership regarding a cooling problem, which went from one thing to the next.. Latest problem turned out to be a blockage in the heater core.
Question is... The expansion tank is about a half inch below the cold fill range.
... is Prestone's Dex-cool ok to add to the stuff that they use at the dealership? (I have some left from when I did the T-Stat)
And did I read somewhere to use distilled water to mix it with?
02 ram 1500 4.7
Thanks Guys.
Old Oct 9, 2009 | 08:16 PM
HammerZ71's Avatar
HammerZ71
DO NOT USE DEX-COOL IN ANY RADIATOR YOU CARE ABOUT!!!
http://www.consumeraffairs.com/autom...m_dexcool.html
Old Oct 9, 2009 | 08:35 PM
dirtydog's Avatar
dirtydog
Moderate User
Just get the Prestone stuff that mixes with any color.
And yes, distilled water is best to use as there are no contaminants to hurt the insides of the radiator as Dexcool does in Hammer's link.
Old Oct 9, 2009 | 10:06 PM
lxman1's Avatar
lxman1
Site Moderator
+2 on distilled water and NO Dexi-crap. The Prestone for all makes and models is what I would get as well.
I would just add the distilled water if it is only a little low in the overflow bottle like you said.
Old Oct 10, 2009 | 07:18 AM
Snaximus's Avatar
Snaximus
Okay Okay !!! I won't use the Dex-Cool !!!
(i'll leave it out for the neighborhood strays) JUST KIDDING !!!!!!
Thanks so much guys, for the very valuable information !
Old Oct 10, 2009 | 09:23 AM
Snaximus's Avatar
Snaximus
HOLY COW...
I just got off that link that Hammer posted above... The Dex is what we used when we did the thermostat this time last year.... low and behold, 6 months later, warped heads, clogged radiator, and now most recently the clogged heater core.
Probably just speculation that the coolant was the culprit, but, there's no substitute for good research. I wish I saw that last year.
Snax
Old Oct 10, 2009 | 10:51 AM
ramhunter9's Avatar
ramhunter9
im with dogg
