front end squeaking
Old Oct 10, 2009 | 03:43 PM
suzuki750's Avatar
suzuki750
Default front end squeaking
my 07 ram 1500 qc 4x4 has had a squeak/clunking type of noise in the front end for a while now and I can never figure out where it is coming from. It's definitely coming from the drivers side, I'm almost sure it's the shock absorber itself making the noise. If I go over a speed bump slowly, as the suspension compresses down it makes a loud squeak. Any ideas?? Is it a good possibility the shock absorber is just toast?
Old Oct 10, 2009 | 03:53 PM
Xanlamin's Avatar
Xanlamin
My 2500 Qcab 4x4 w/2" leveling kit was doing the same thing, I greased my fittings and it has since stopped.
Old Oct 10, 2009 | 04:35 PM
suzuki750's Avatar
suzuki750
what fittings are u talking about that u greased
Old Oct 10, 2009 | 05:39 PM
texas red's Avatar
texas red
my "struts" as of 06 dodge got rid of shocks in design on our 1500's 2x2 an 4x4 models softer car like ride they were tryin to attain. were crap and leaked alot and drvr side was blown out totaly by 30k squeaked badly. I used monroes sensa tracs part num 71111 if i remem right....
Old Oct 10, 2009 | 05:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Try a shot or two of PB Blaster or some other GOOD penetrating oil and see if helps.
Old Oct 10, 2009 | 08:14 PM
suzuki750's Avatar
suzuki750
just completely removed the sway bar off the truck to see if that was the problem, still same clunk/squeak. Got the front wheel off right now, sprayed the hell out of every pivot/ball joint on the front suspension with penetrating spray to see if it helps. Gonna let it sit for a few and hit it again with the spray
Old Oct 13, 2009 | 08:27 PM
Xanlamin's Avatar
Xanlamin
behind the brakes, below the axle, there is a fitting to grease
Old Oct 13, 2009 | 09:57 PM
BadHab1t's Avatar
BadHab1t
what about control arm bushings? they could be spent....
Old Oct 13, 2009 | 10:27 PM
02dodgeram5.9's Avatar
02dodgeram5.9
I recently got the same problem..Just installed a leveling kit and new shocks on the front and got it all aligned..but now i got the same sqeak and rubbing type noise that you have..i dunno where to look..help me out..
Old Oct 13, 2009 | 10:45 PM
rcman0056's Avatar
rcman0056
My squeak is coming from where the shock and the control arm meet. The bushing between the two is worn out and squeaking. Still on the to do list.
