Transmission fluid
Old Oct 14, 2009 | 12:03 PM
Pysiek's Avatar
Pysiek
Originally Posted by shadow11
Follow these instructions here and you will be fine http://www.60ateight.com/DodgeRam/
This is a GREAT write up.
Thanks
Old Oct 15, 2009 | 11:23 PM
Dodgeboy77's Avatar
Dodgeboy77
IDK what the scary part is about changing all the dirty , varnished oil in a high mileage trans. to me , get all the old crap out of there so you can start clean. thats just me, but i am not sure , maybe there is a reason to leave some old oil in.
Old Oct 16, 2009 | 12:05 AM
cheapbeater's Avatar
cheapbeater
i dont see the problem with flushing a high mileage tranny, as long as it is done with a pump inlet machine by a capable mechanic it is the way to go. the problem with some trans flushes is when they dont drop the pan, they just push everything throught the tranny, this loosens up all the crap which can stick in the valves and what not... so if they use a pump inlet machine they have to drop the pan to hook it up, and if you get a good shop they will look things over, clean the valves up, and run a diagnostic test...
i looked everywhere for a place by me that did a pump inlet flush, and couldnt believe that some of the tranny shops didnt even know what i was talking about. finally i found a shop, and they did everything for $180... in 30000mi i'm going back there to have it done again...
Old Oct 16, 2009 | 04:22 AM
Bluesmanjesse's Avatar
Bluesmanjesse
Originally Posted by MikeHTally
Ah, yeah. The book says every 30K. Make sure you get the right filter. Not sure what tranny you have, but often the filters are different for the 4x4s. Ditto on the "no flush". Too many miles on it now. You could let the pump flush it for you. Sounds more time-consuming, though.
Not that I agree with it but my book says at 100,000 change the fluid.
Old Oct 16, 2009 | 04:25 AM
abarmby's Avatar
abarmby
cheapbeater hit the nail on the head about how some trans flushes dont drop the pan, they just push everything throught the tranny, this loosens up all the crap which can stick in the valves and what not.
That's what can happen. Not definately......but can???
Too much of a risk for me.
Al.
Old Oct 24, 2009 | 09:04 AM
MikeHTally's Avatar
MikeHTally
Maybe you're looking at kilometers -- the '06 shop manual says "drain and refill... and change main sump filter" every 60K miles. The interval was doubled in '04 or '05. The '03 manual says every 30K for the tranny and 15K for the diff.
Old Oct 24, 2009 | 04:16 PM
Bluesmanjesse
I ain't no canadian,it says miles man.
Old Oct 24, 2009 | 04:59 PM
MikeHTally's Avatar
MikeHTally
Time to change manuals.
Old Oct 24, 2009 | 05:10 PM
MikeHTally's Avatar
MikeHTally
Sorry, double post.
Old Oct 25, 2009 | 03:49 PM
Bluesmanjesse
Cool,like I said I don't agree with it but that's what it says!
