Removing the grill inserts
Old Oct 14, 2009 | 01:38 PM
oefootball_70's Avatar
oefootball_70
Default Removing the grill inserts
Anybody have any pointers? I tried searching and it tells me that it can't find anything no matter what I search. I am not for sure if it is my computer or what. I would appreciate any help, sorry for the repost if it has been done before.
OE
Old Oct 14, 2009 | 02:20 PM
disturbedgator's Avatar
disturbedgator
are you talking about the little miny body pins that hold them in? all you have do to is push the center through. dont worry bro i nearly lost it when i changed mine out. get a tiny screw driver and push them through.
Old Oct 14, 2009 | 03:19 PM
oefootball_70
You mean from the back side push them? I already broke one. Does anybody have the OEM part number for these little biotches. It might be easier to break them all off and replace them. I just cant seem to get them to slide out. Maybe wd40 will help.
Old Oct 14, 2009 | 03:25 PM
BadHab1t's Avatar
BadHab1t
mine were all lil plastic welds and i just broke em all and when i replace with gutter grill i used zip ties good black ones they work well
Old Oct 14, 2009 | 03:29 PM
Ramdamit98's Avatar
Ramdamit98
I pulled my whole grill assembly off and then just pushed them straight through into the assembly with the grill sitting face down on the floor in the house. Then just collected all the little pieces after I had the grill inserts out, so I could replace it later.
Old Oct 14, 2009 | 03:42 PM
TRXHemi's Avatar
TRXHemi
There are plastic hooks that snap into it. They are a pain in the A$$ to get out. Be careful and take your time.
Old Oct 14, 2009 | 05:47 PM
disturbedgator
these little pins are what im talking about, if you have the same setup, just push the little middle piece all the way through and just collect the little pieces after your done
Old Oct 14, 2009 | 05:53 PM
JohnnysArt's Avatar
JohnnysArt
Exactly, thats the way I did it.
Old Oct 14, 2009 | 08:59 PM
oefootball_70
Can you see the zip ties?
Old Oct 14, 2009 | 10:14 PM
fandd5@msn.com's Avatar
fandd5@msn.com
Ya i replaced mine too, I used a pair of needle nose plyers. Just take your time and try not to get frustrated. And the other ones snap in.
