Engine light came on :(
Old Oct 17, 2009 | 12:19 PM
gonus's Avatar
gonus
Default Engine light came on :(
Engine light came on. I took it to Advanced Auto to get the code. It was cylinder 1 misfire.
I replace the spark plugs.
Had code cleared.
It came back. Replace the coil on top of plug.
New error shows up with multiple cylinder misfires.
I check wiring to ensure that I put everything back nice and purty.
I took it to a mechanic. They went through the above checking my work and then checked the fuel injectors pressure. it was fine.
I was informed by the shop that it could be a blown head gasket or acracked heads.
I did a pressure test on all the cylinders. They all came back with around 160.
If it was a blown gasket/cracked head, wouldn't I have low pressure?
A friend suggested crankshaft position sensor and camshaft sensor position sensor reciting a dodge van he worked on a bit back had the same symptoms.
Any Gurus care to make a suggestion for a new guy?
Old Oct 17, 2009 | 12:45 PM
chambers's Avatar
chambers
Well the compression seems fine, and I think the position sensors usually throw codes. Is the truck running rough or just spitting the misfire code at you and running fine?
Old Oct 17, 2009 | 02:49 PM
nh5's Avatar
nh5
What engine? 5.7, 4.7, 3.7? 4.7's have head issues. If the pressures good your probably looking at a sensor. Also any loss of coolant at all?
Old Oct 17, 2009 | 04:30 PM
gonus's Avatar
gonus
I need to apologize for double posting. I looked for all post by me and none were listed so I reposted.
It running rough only when first started. After a few seconds it runs fine.
It is a 4.7. I do not have any coolant on my drive way. I didn't check the coolant lvl before taking it to the mechanic. I do not have the milky oil associated with antifreeze/coolant in the oil.
I appreciate it all suggestions.
Bruce
Old Oct 17, 2009 | 05:05 PM
CarGuyOhio's Avatar
CarGuyOhio
When you changed the plugs what did they look like? Dark black, dry, wet, ect.
http://www.spark-plugs.co.uk/pages/t.../diagnosis.htm
Old Oct 17, 2009 | 09:16 PM
gonus's Avatar
gonus
All the spark plugs were normal.
Old Oct 17, 2009 | 09:40 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
How does the truck run? Any misses?
Old Oct 17, 2009 | 10:53 PM
gonus's Avatar
gonus
It has only missed when first started. After a few seconds it runs fine.
Old Oct 18, 2009 | 05:30 PM
gonus's Avatar
gonus
I replaced the crankshaft position sensor with np. It looked dirty but the o-ring was fine. I can't locate the camshaft position sensor. Any one able to shine some light on that? A pic would be beautiful. My haynes book says where but I can't locate it. I am an engine newb.
Found it. Just like book says front right. Passenger side. Key word Passenger. I was on wrong side.
Old Oct 18, 2009 | 08:27 PM
lxman1's Avatar
lxman1
Site Moderator
Soinds like maybe a little coolant fouling the plug after shutting down the engine. Might want to do a coolant system pressure test to make sure you don't have a head gasket seeping. 4.7's are known to do this.
