Disable Auto Shut off Heated Seats Ram 2008
Old Oct 20, 2009 | 02:26 PM
BroncoDakota's Avatar
BroncoDakota
Default Disable Auto Shut off Heated Seats Ram 2008
Something that just annoys me in the mornings with the remote star does not activate heated seats if they are set the night before. The ignition resets them once you turn the truck off. Is there anyway to diasable this?? It would be quite nice to have a warm seat to go out to in the morning! Any ideas? As if the wires from the back of the heated seat buttons goes directly to the ignition to cause a reset??
I have a 2008 Dodge Ram Laramie
Old Oct 20, 2009 | 02:56 PM
dirtydog's Avatar
dirtydog
Moderate User
i could help if i had a wiring diagram???
All Data anyone??
Old Oct 20, 2009 | 03:04 PM
Shiloh 24's Avatar
Shiloh 24
Could you swap the button and replace it with a toggle switch and then run a relay that gives it power when the truck is running?
Old Oct 20, 2009 | 04:16 PM
BroncoDakota
A wiring diagram would be helpful. Anyone?? Would you just want to cut the wire to the relay.. Mmmm?
Old Oct 20, 2009 | 04:58 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive got AllData at home and will try to get it when i get there
Old Oct 20, 2009 | 08:02 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Here are those schematics. This link is only good for a bout 7 days and will expire.
https://www.yousendit.com/download/Z...TkxENlN4dnc9PQ
Old Oct 21, 2009 | 12:38 PM
BroncoDakota
Thanks for the diagram!
Dirtydog can you tell from these??
Old Oct 21, 2009 | 08:57 PM
HemiLonestar's Avatar
HemiLonestar
I imagine there's a reason for this, maybe so the heating elements don't overheat and set the seat on fire?
Old Oct 22, 2009 | 01:41 PM
BroncoDakota
What's the difference? The truck will shut off automatically in 15 minutes.
Old Oct 22, 2009 | 03:27 PM
dirtydog's Avatar
dirtydog
Moderate User
The Alldata info doesn't give the entire circuit which make it a bit difficult, but my guess is that on the fusable locations 1+2, those are both powered by the ignition to go on/off. It would be a bit of work to get it to function the way you want but it is possible. A relay and a few diodes are likely needed along with a steady power source. i would need to see the entire circuit from seats to fuse panel or atleast porbe wires and do some testing before i can say for sure what would work.
