Stalling problems
Old Oct 21, 2009 | 12:10 PM
mectbone's Avatar
mectbone
Angry Stalling problems
I have a 2004 Dodge Ram with a 4.7L V8 in it. I recently had the water pump replaced this summer in June or July and found out this past weekend that I had no coolant in the block but there was some in the radiator so I know that was causing the overheating. However the last couple of months I have been having more and more stalling problems. I took it to the dealership but of course they can't duplicate the problem. Although on my way home it stalls on me again. It only stalls when I'm coming to a stop at a light or sign or stop in general. I have no problems accelerating even putting the pedal to the floor or at constant speed. My truck will sit at idle. After it stalls it will crank right back up but it will idle near 1000 for 10 - 15 seconds, usual idle speed is between 650 and 700. The dealership gave me 3 recommendations: replace the IAC motor, throttle body cleaning, and EFI cleaning. Has anyone had this problem and have any better suggestions? I have not replaced the motor just yet as I had to order the part. I'm going to change that out and see if that works but I'm at a loss if it continues.
Old Oct 21, 2009 | 01:27 PM
ramhunter9's Avatar
ramhunter9
new IAC and a good TB clean and a can of sea foam. your good to go all things you can do in the driveway
Old Oct 21, 2009 | 01:31 PM
mectbone's Avatar
mectbone
Thanks. Here's hoping this works. I'm tired of the stalling every 5 - 10 stops.
Old Oct 21, 2009 | 01:38 PM
ramhunter9's Avatar
ramhunter9
you will be fine just do what i recomended. get one can of seafoam in the gas (full tank and one in the crank. take the TB off clean it really good put on new IAC and while your at it check filter
Old Oct 21, 2009 | 01:41 PM
mectbone's Avatar
mectbone
which filter, air filter?
Old Oct 21, 2009 | 01:46 PM
ramhunter9's Avatar
ramhunter9
yes
and check for restriction in the box to the TB
Old Oct 21, 2009 | 02:00 PM
mectbone's Avatar
mectbone
the filter is still pretty clean and there is absolutely nothing in the box between the filter and the throttle body. I'm surprised how clean that box looks. Just like it was brand new out of the show room.
Old Oct 21, 2009 | 02:27 PM
ramhunter9's Avatar
ramhunter9
thats a good thing now is your TB caked in black muddy build up??
Old Oct 21, 2009 | 02:39 PM
mectbone's Avatar
mectbone
There is some black build up. My part just came in so I'm on my way to go fix this problem right now. Thanks for the help.
