Died just like that
Old Oct 23, 2009 | 06:26 AM
Pysiek's Avatar
Pysiek
Default Died just like that
Everything was fine on wednesday. I drive the truck to work,works perfectly. Then I leave it for the night on my driveway and can't start it in the morning. I know there wasn't much gas in the tank but the reserve light wasn't on yet.
Electric works fine,radio on,lights on.Engine crank but won't start.
What can be the problem?
I try to start it with my key and with remote starter...same thing.
Please help I need that truck for weekend
Old Oct 23, 2009 | 09:47 AM
dirtydog's Avatar
dirtydog
Moderate User
why don't you try and pour 5 gallons of fuel in there. if you run the gas down to 1/8th tank al the time, that will eventually burn up your fuel pump. When you turn your key on, can you hear your fuel pump priming? should only last like 2 seconds so keep your doors and ears open.
Old Oct 23, 2009 | 11:00 AM
Pysiek's Avatar
Pysiek
I will let you know later. Now I'm at work.
Old Oct 23, 2009 | 11:37 AM
Pysiek's Avatar
Pysiek
Is there any other way to check the fuel pump?
Old Oct 23, 2009 | 11:48 AM
motorhead426's Avatar
motorhead426
I've always run my fuel tanks down way past the light coming on and I've never burned up a pump. Now if the light comes on, and I fill it just until the light turns off (like if there is never more than 5gal in it) then I might be able to believe it would burn the pump out. I completely agree that the fuel in the tank cools the pump. I have just never seen anyone that actually burned up a pump that way... Just my $.02
Old Oct 23, 2009 | 11:51 AM
motorhead426
Are you getting enough amerage to the engine to start it. I've had problems with past cars where I had a bad ground strap, or corroded positive cable that kept the engine from starting. Everything else might work, but it's just enough to keep the ignition system from firing. If filling the tank, and verifying your pump is not at fault, then I'd look for an electrical system issue.
Old Oct 23, 2009 | 12:00 PM
dunerider650's Avatar
dunerider650
does it even attempt to start?? make sure you got fuel, power, then check see if ya got spark
Old Oct 23, 2009 | 12:40 PM
jfrerichs89's Avatar
jfrerichs89
guy on my ball team always drove it low on gas and well today, him and his dad spent 2 hours changing out the fuel pump in the parking lot in the rain. His truck electrical worked and everything and the truck would try and turn but wouldnt fire up... Sounds similar, I think
Old Oct 23, 2009 | 12:54 PM
rtmtrrdr's Avatar
rtmtrrdr
It happened to me on my old ranger i had and in my dads 2500.we both kept running it down almost to empty,eventually it burned up the pumps
Old Oct 23, 2009 | 02:26 PM
Pysiek's Avatar
Pysiek
I'm happy now because I just bought a house. Now I can do projects on my Dodge and nobody will bitchin about it.
