Torsion leveling and front end wear
Old Oct 28, 2009 | 08:26 PM
mrbrace's Avatar
mrbrace
I did the keys and I needed shocks because my stock shocks were too short. Superlift makes good shocks that are slightly taller for the 2" level.
Old Oct 28, 2009 | 08:48 PM
JohnnysArt's Avatar
JohnnysArt
I leveled mine with new keys from procomp and all new shocks including longer ones for the front.
Rides just fine.
Old Oct 29, 2009 | 12:10 AM
bigmiah22's Avatar
bigmiah22
Just crank up the torsion keys, its free and easy and all that's needed is an alignment, which you'll need whether you crank them or put new ones in. Theres a bolt on each side of the underbody of the truck that cranks your torsion keys up or down, just make sure you spray some pb rust inhibitor on them and get a torque wrench and rotate them 2 turns each, take a look at where your truck sits, and if you want to go higher, crank them some more, just make sure you turn them the same amount on both sides. It also makes it easier if you jack your front end up off the ground, turning the bolts are a lot easier this way.
