2500 u joints?
Old Oct 25, 2009 | 09:30 PM
draco8494's Avatar
draco8494
Default 2500 u joints?
it seems that my u-joints are finally failing, i hear some poping noises every once n a while at slow speeds, now onto the fun part, i know how to change u joints with a retainer clip.....how do you change the u joints on the front D-shaft?? i know they have some sort of burn out typ of retainer, i should be able to get that with a regular propane torch or something of the like right? and how does it go back in??? maybe some 1 has a FSM for a 2500? cuz yeah haynes has allmost nothing in it for a 2500 thanks guys
Old Oct 26, 2009 | 08:42 PM
draco8494's Avatar
draco8494
noooooobody knows?
Old Oct 26, 2009 | 08:56 PM
hemiguy0302's Avatar
hemiguy0302
sorry dude I have no idea I even had the shafts out when i did the diffs but they looked nice and tight still so we skipped over changing them. Bump anyways.
Old Oct 26, 2009 | 09:01 PM
lxman1's Avatar
lxman1
Site Moderator
Most of us have little ole 1500's I guess. I never even payed any attention to mine. But I have a 2wd with a huge aluminum driveshaft.
Old Oct 26, 2009 | 09:03 PM
draco8494's Avatar
draco8494
yeah mines huge, and i wish it was aluminum, cuz its all rusty but alas i guess ill change the rear myself, n take the front to a shop or something....unless some 1 els know
Old Oct 27, 2009 | 12:31 AM
i-love-my-dodge's Avatar
i-love-my-dodge
A propane torch will work.heat it up untill both "ears" have no more plastic coming out of all 4 holes( 2 on each side) and then its like a regular u-joint. then the new ones are held in with the regular clips. If you havent done a cv before I would suggest buying a spare joint while at the store. They become second nature when you do alot though lol. Also check your axle u-joints as they are common on the dodges as well. good luck.
